Just dropped mine off today as well 82miles started around 78 and now you can still hear it even when the engine is warm you have to practically get under the fender to hear it but you can hear it go over to the drivers side and she’s silentFinally took my 2019 1500 into the dealer with an exhaust leak thinking it was the bolts that had sheared off. It turns out it is a cracked Manifold after only 17K on the truck. Luckily its covered under the warranty. But it took them a Day and 1/2 just to get b past all the Heat shields to actually to get to the manifold.
Get them replaced under warranty. I believe they are on their 3rd redesign and are likely good to go.Same issue 33k miles 2019 truck. Is it even worth it claiming through the power train warranty or go full shorty headers. How long do I have before I mess something up like the head driving around like this ? Any assistance is appreciated
Thank you sir ! Sounds bit promising but I will take that advise and drop the truck shortly.Get them replaced under warranty. I believe they are on their 3rd redesign and are likely good to go.
That's a long shot. How do you know this?Get them replaced under warranty. I believe they are on their 3rd redesign and are likely good to go.
How's that a long shot? The info is posted in many threads on this forum, including the most recent manifold part number (the last two letters are the version of the part - if it's been updated).That's a long shot. How do you know this?
They will change part numbers if they use a different manufacturer, it doesn't always mean it's a redesign when they do so. Not saying you are wrong, just simply saying that I haven't seen any hard facts saying there was a redesign.How's that a long shot? The info is posted in many threads on this forum, including the most recent manifold part number (the last two letters are the version of the part - if it's been updated).
**I may have been thinking of another part, I can only find the AB manifold part numbers during a quick search.
Here's the TSB showing the AA part, and it being superceded by the AB if you go to order it.
I'm at 61,000 miles on my '19 and no exhaust manifold leak yet...![]()
I've had mine changed three times now and have been told every time it's the same manifold.
There is a picture somewhere in one of these threads, showing side by side. They have been redesigned, with a little more meat, in an area prone to cracking. You have to be side by side to see subtle difference.They will change part numbers if they use a different manufacturer, it doesn't always mean it's a redesign when they do so. Not saying you are wrong, just simply saying that I haven't seen any hard facts saying there was a redesign.
That is a great shot. Thanks!View attachment 177573
Just in case someone is wondering how bad the crack on mine was lol worse than one on a drought land ! Glad I listened to @firecadet613![]()
Welcome ! This was shot while it was still on with wheel well and everything removed and the crack was on the worse possible side on mine which is drivers (passenger is easy) which has the steering shaft and all things that come along with it. But thankfully it was covered under power train warranty took 2 days for them to get the part in. Good luck with yours and get it done under pt warrantyThat is a great shot. Thanks!
Was it difficult, did you have to remove anything to take that picture. Was it taken from above or below?
