Rear window surround crack.
Rando
So, I am on replacement window number 2 and it's been cold the last few mornings and I noticed my defroster is not working on the right glass, center and left side glass working. Ugh....
Not sure if I want to have them replace it again or just deal with it...
I’m on window number 3. I noticed the same thing this week. Defroster is no longer working. On another post someone mentioned that the contacts in the corner snap off or get rubbed thin during replacement. I haven’t had time to pull rear seats for a better look.
will4ya
Lyman, SC
I have a 2021 Ram Laramie (18K miles) and just took it to the Dealership for a rear seat leak passenger side. They just called and informed me there is a crack in the frame and a replacement was ordered and the whole window will be replaced under warranty.
Ellisstrong
Atlanta Ga area
My truck is 5 years old and I’ve never had the cracked rear window. I did have the leaking brake light and had my headliner replaced when it leaked so they removed my rear window to replace it and installed a new one. This was in my first year of ownership though. So I guess my rear window is about 4.5 years old
Maybe I jinxed myself with this one as I had to develop the leak maybe a month at most after this. I’ve been waiting on a back window since some time in January and I finally was updated today after they told me it would be in by the end of January. New tentative eta is 2/28…
cerbo
TN
does anyone know if they ve re designed 2024 rear windows or stop lights. ??
I mean by now you d think they would.
theblet
The high mount stop lamp gasket was redesigned before 2024 not sure about the window. Something tells me no
cerbo
TN
Which vid? It’s pulling up a bunch of them
The top one, works on my end. I posted 2. I like the silicone one better just in case it has to come apart. Polly would be harder to remove but same procedure.
cerbo
TN
so here s a 2024 (built 12/23). see attached, looks like MAYBE the frame has changed as I don t see that faint discoloration line where the seam is. Someone posted a picture of that seam area that s lighter in color.
Just some info for those with issues.
