Dogpatch
Coldstream, BC
Just ordered the Carlinkit 4.0 Wireless CarPlay.
I’ve had the 2.0 version for a few years. This newer model is the 4.0 and is compatible with both iOS and Android. Supposed to be 10x faster and do a few more things. Carlinkit also has AI Boxes.
Heres a link in case any of you are interested.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Neat.
What I like about wired connection is that it keeps my phone charged.
Dogpatch
Coldstream, BC
Neat.
I use a Course Motorsports MagSafe Charging Mount. I get in my truck, set my phone against the magnetic mount, it charges while there and when I start the truck, automatically connects to my radio screen and system.
It works for me!
Dogpatch
Coldstream, BC
Need to look into that
Here‘s a link to my mount. Connects behind the radio bezel.
Here’s a link to the charging part of the mount. I ran the wire down in behind my radio bezel so that no wires show anywhere.
They have really good support to help you get exactly what you want.
Asahdev17
put in some lights for the running boards. Don’t know why ram coulda have done this on their own 🤦‍♂️ but still looks great and closes when the running board goes back in
1BADRAMLIMITED
Oklahoma
Link to the lights u used? Where did u pull power from?
Did you mount the light to the frame?
1BADRAMLIMITED
Oklahoma
Dam I just bought the 2.0 from a fellow member for $40 few bucks more I could have gotten the new new
Fbird
It works for me!
yup I recently installed this in mine too. Is it worth the $80 ...probably NOT as I ordered a similar charger for my son @ $30. Same type of holding same rate of charging same ball joint type swivel........only thing different was ^^^^^^ has a little 3" long piece of metal to place it in the perfect place!!!
CHeYeNNe71
What's the difference between 4.0 and 5.0 that you didn't grab the 5.0?
Asahdev17
Here are the link to the lights https://a.co/d/1LcViz0
I pulled it from the towing outlet positive one. But I put a limit switch on it so it wouldn’t stay on all the time only when the doors are open and power steps come out.
Belvedere
Do you not have the puddle lamps in your mirrors?
PurpleRT
This. I personally never bothered to install the amp lights on my 5th gen… never felt the need with the puddle lamps I can see the steps just fine.
Belvedere
Even with them I'm still considering adding the same setup.
I guess another question would be, if you have puddle lamps are they LED? I have LED lamps and they are very bright. Not sure if there is comparison, but my buddy's 2500 has halogen puddle lamps and they're very dim. He used the AMP lights.
