Trooper4
- Feb 14, 2019
- Location
- KITTITAS, Washington
Only 1/2 ton trailer fails I've seen is with bumper pulls.
I got no issues with 1.5 but mine are on stock 20" wheels. Best thing for you woild be to remove one wheel and measure like others have mentioned. Chances are you will be fine but better double check before you order them. I got a total 2.5 front level so no rubbing with 33" tires.My worry was that the oem lugs may stick out from the spacers when putting them on and didn't want to have to trim them down at all. Does the 1.5 have this happen at all? And obviously hoping for no wheel rubbing. I have the rebel trim and is I believe a stock 2 inch lift
How are those tires in the rain? They look amazing, thinking about moving from the Wildpeaks ATW3 to those!Bora 1.25” front 1.5” rear
Seem to do well enough. No complants really. My real test will be snow, though they’re 3 peak snow rated so should be fine.How are those tires in the rain? They look amazing, thinking about moving from the Wildpeaks ATW3 to those!
Do you still have these spacers on your truck? If so, still liking them? I want to order a set, just deciding on 1.5 or 2”I have 2” KSP spacers on my limited and works fine. I’ve put 5k (no off-roading) and just did a tire rotation and checked everything over. No complaints here.
Yes i do. I recently did a tire rotation and checked and re torqued them they look like new no shearing or issues so far.Do you still have these spacers on your truck? If so, still liking them? I want to order a set, just deciding on 1.5 or 2”
I'm with you at 1.5 or under. I know others will run a 2", but that's quite a bit.Yes i do. I recently did a tire rotation and checked and re torqued them they look like new no shearing or issues so far.
I’d do 1.5 or 1” 2 is just too much
How wide are those tires and what offset at your wheels?
Thanks buddy!The answer u seek is in his signature. He’s running 3/4 rear spacers and 1” front spacers.
Stock wheels are +18 offset
285/65/20 (factory is 275/55/20)
If hubcentric, cleaned surfaces and installed properly, shouldn't be any issues.I just installed the rough country 1/4" spacers. Will see how the driving is at higher speed tomrrow.
So far so good.If hubcentric, cleaned surfaces and installed properly, shouldn't be any issues.
Looks great. Do you have side pics? I'm trying to decide between 285/65, 275/65, or 285/60 r20 45lb oe falken tire to a 60lb tire? Any negatives?
