Is anyone using wheel spacers on a 5th gen ram 1500? I have a 2020 ram 1500 and I was considering it but wanted to get some thoughts on it. Do you recommend them and have you had any issues using them let's say like a 2 inch wheel spacer?
First thing that comes to mind, did you make sure the hub mating surface was free of rust or debris? Also, did you torque the spacer lug nuts and wheel lug nuts to spec?Had mine on for about a month now. Bora. 1-1/4”, hubcentric. Looks great, but I seem to feel a slight light thump or vibration….feels like a mild wash board. Not sure what it could be, had tires balanced and rotated still doing it. Anyone have any. Thoughts…?
I don’t think you need to go crazy with the mating surfaces. I basically just wiped mine down and checked for imperfections. Sounds like you should be good. Do your tires have any cupping or excessive wear?Torqued the spacer and then the wheel to 130ftlb drove for 50 miles and checked all looked good. I made sure the hub was clean, I did not scrape or wire wheel as it looked pretty good. I could try to clean better…??
I’m thinking of going with 1/2” Bora’s. But if 3/8” gets me flush, I might go that route. You say yours are flush, so im guess you don’t have Factory fender flares? I do not either.Running 3/8 BORA’s front and back. Bought mainly to clear my UCA’s when I bought my Toyo AT3’s. No longer running the Toyo’s and really don’t need them now, but I like the flush look they provide so I left them on. Zero issues with them.
Have any pics from the side that shows how flush they are? Thanks in advance.
Here's my bighorn with OEM 18" rebel wheels. I put Bora 1" on the rear and 3/4" on the front.I’m thinking of going with 1/2” Bora’s. But if 3/8” gets me flush, I might go that route. You say yours are flush, so im guess you don’t have Factory fender flares? I do not either.
Here you go...Just so happen to be in my garage, so I snapped this...
Running 285/55's, so about 11.2 inches wide.
They sat out farther with my Toyo's. Flaps and no flares.
What I like most is zero rocker/side panel carnage.
Great looking rig. Did you have to trim your lugs to for the 3/4” and 1” spacers? I’m trying to avoid that and my research is leading me to either under 1/2” spacers or 1 1.25” spacers. But without flares, I think 1.25 is too much poke.Here's my bighorn with OEM 18" rebel wheels. I put Bora 1" on the rear and 3/4" on the front.
There is some poke, but these tires' treads aren't as wide as the overall tire width, so the tread doesn't poke as much as the whole tire does.
Thanks!Great looking rig. Did you have to trim your lugs to for the 3/4” and 1” spacers? I’m trying to avoid that and my research is leading me to either under 1/2” spacers or 1 1.25” spacers. But without flares, I think 1.25 is too much poke.
