vietatran05
- Jan 3, 2021
This might be another good option. Too bad it’s currently out of stock. https://www.readylift.com/1-5-leveling-kit-with-tubular-upper-control-arms-air-ride-equipped.html
yes it will. depending on how short the links are, the offroad 2 mode may not be usuable thoughSo I have the front & rear lifting links kit, (I think Revel). I just want the truck to sit level or very close to it. I would like to use a slightly bigger tire. 285/75/18 which is only about 1 1/2" taller than stock 275 70/18. The air ride still functions properly after adding the leveling links?
So adding about 1 1/2 inch increase in the front for a more level ride should allow the modes to still function properly? I dont really use the off road mode. It reduces height automatically when going faster than 15 mph. anyways.. Does anyone know if this stops the aero dynamic node from coming on?yes it will. depending on how short the links are, the offroad 2 mode may not be usuable though
i made my own iinks from threaded rod and ball stud sockets. aero works fine, i can use off road 1 if i wanted too, but not off road 2. i use neither off road modes honestlySo adding about 1 1/2 inch increase in the front for a more level ride should allow the modes to still function properly? I dont really use the off road mode. It reduces height automatically when going faster than 15 mph. anyways.. Does anyone know if this stops the aero dynamic node from coming on?
If you set them too high it will affect the offroad modes. It will also ride harsh. I have never seen them affect Aero mode. We played with them a lot on our Rebel when we had it.So adding about 1 1/2 inch increase in the front for a more level ride should allow the modes to still function properly? I dont really use the off road mode. It reduces height automatically when going faster than 15 mph. anyways.. Does anyone know if this stops the aero dynamic node from coming on?
Do you do installs? I'm west valleyOur links are adjustable. You can get level or real close to it and still have full functionality of all modes. If you shorten the links too much for too much lift, it will ride rough and cause air suspension errors or issues with some modes not work as stated above. On our Rebel, we were level and all modes still worked. It also still rode good.
Metal End Lift Link 5th Gen Ram With Air Suspension | Shifts and Grins Fabrication LLC
5th Gen Ram Air Suspension Links (2019-2021). These links adjustable to provide different amounts of lift to suit your needs. We set them to lift the Ram Rebel approximately 1.25" which is what we found to be a good amount of lift while avoiding some of the undesirable effects from setting them...www.shiftsandgrinsfabrication.comPlastic Link End Air Lift Links for 5th Gen Ram 1500 | Shifts and Grins Fabrication LLC
Not typically. I can walk you through it though. We also have installation instructions with photos.Do you do installs? I'm west valley
