Cltremblay
- Dec 12, 2018
Hi all at 5thgenrams.com!
If you are having a hard time understanding or calculating your truck's Payload or Max Trailer Tow capacity based on your specific vehicle's configuration, look no further!
I have put together a comprehensive guide to help everyone understand how FCA has determined and specified this information for the all new 2019 RAM 1500.
There is a lot of information in this post, I felt it was important to provide as much information as possible in all aspects of this discussion.
Okay, shut up already, right? So here it is, everything you need to know. There is A LOT of information here.
I have sourced and compiled all of the information directly from FCA with the hope that it helps everyone understand how and what FCA uses to calculate the towing capacity specifications for the 2019 RAM 1500 in all configurations, trim levels and available options w/ weights for both US and Canada markets and the direct correlation they have with available Payload, GVW and GCW ratings. See all of the attached documents from FCA.
1) INTRODUCTION |
A little bit about myself to help put at ease any doubts about my qualifications in presenting this information. I am a licensed Journeyman Mechanic by trade in Canada and work for a large organization with one of the largest self-owned and self-maintained fleets in Canada. I work in the Engineering and Capital Fleet Procurement side of the organization where we write all of our own required specifications, ensuring that all applicable laws and regulations are followed, for our fleet vehicles and equipment before sending them out to tender. Therefore, acquiring, interpreting and understanding this information is a routine part of what I do for a living. I decided to put this guide together is because I found that on my own quest to source this information, it was not all in one place for owners, making it more difficult to find from FCA, compared to other vehicle manufacturers. I stumbled onto this forum where I found that in many of the posts/threads, there seemed to be a lot of confusion from owners about the MAX AVAILABLE TOWING Vs. the ACTUAL TOWING capabilities of the trucks they actually bought. There are so many configurations, trim levels and available options. It's important to understand how they all impact available available Payload, Gross Vehicle Weight and Rating, and the Gross Combined Vehicle Weight and Rating. |
2) DISCUSSION |
I can't stress this enough! Know what you want and know what you need! Know what the final product can do before you buy it! Know what trim, configuration and options you want/need and understand how they will affect your truck's capabilities! DO YOUR HOMEWORK. 'THE RAM DEALER TOLD ME IT COULD!' You would be surprised to know just how inaccurate some of the information provided by a dealership or salesperson can be. Of course, this isn't always the case, you may be getting accurate information from a dealership who has also done their homework. Knowing for sure is very important before you embark on your truck hunt! You're about to (or already have) spend a lot of money on a truck that suits your needs for many years to come! Make sure the final product can do what you need it to! Now, this isn't to say that sales people are lying to you or are trying to trick you! That's not the point I'm trying to make here. In all likelihood, they'll provide you with the same information that has been provided to them, or as they understand or interpret it, and may believe it to be accurate! In some cases, the information they're providing to you is of the same information from the manufacturer's literature which, until seeing or searching for this post today, is probably the same information you've all already seen in the brochure. Not all sales people, or truck owners for that matter, have a deep understanding or knowledge of how towing capacity specifications are calculated or determined for the product they sell and that must be taken into consideration. "But wait a minute! The dealer told me my truck could tow 5,783 kg/12,750 lbs and that it has a payload of 1,043 kg/2,300 lbs! I already went out and bought a trailer, tried to buy a trailer and the RV Dealer wouldn't sell it to me, or I already own a trailer and can't tow it! What the hell!" Naturally, you may be a little confused or upset when you take delivery of your sparkling new 2019 RAM 1500 Limited, or other trim level/configuration, loaded with all the options you want/need, and find that on your 'TIRE AND LOADING LABEL' your payload specification is only 549 kg/1,210 lbs and you can only tow a Max trailer weight of 3,052 kg/6,730 lbs! 'THE RV DEALER NEVER TOLD ME IT COULDN'T!' Again of course, this is not always true! Again, consider that the RV dealer may not fully understand the towing capabilities of your vehicle either! Some will flat out refuse to sell you the unit you want due to the restrictions of your tow vehicle's capabilities, where others may not realize they've sold you a unit above your limits, using the information that's been made available to them! DO YOUR HOMEWORK! Not doing the research now to determine the specific towing capabilities of your truck could land you in hot water. I've seen it all too often, half tons driving down the road on a long weekend to go to their favorite camping spot, seriously overweight with all of their gear, toys and travel trailer, some even towing a boat behind it all! These are half ton trucks! It poses a huge safety risk to you, your occupants and everyone else on the road should something happen where you need to make a sudden or evasive maneuver, stop or when weather takes a turn. Obviously, DOT officers have a lot more knowledge, information and understanding of your truck's weight limits. Should you be subjected to a stop.. things can get real expensive, real fast, or worse. "But officer, the RAM dealer told me it could and the RV dealer never told me it couldn't!" As an operator of a vehicle, whether you own it or not, if you are operating it, the responsibility is YOURS to know and understand whether you are operating it within the safe confines of the manufacturer-specified operating limits of that vehicle. If you are stopped by an officer and he or she determines that you are operating outside of those limits, you are likely going to have a bad day. |
3) INCREASING PAYLOAD OR TOWING CAPACITY |
I have seen this question in one or two posts on this forum, "How Can I increase the Payload or Max Towing Capabilities of my truck? What are the limiting factors? What parts can I upgrade so they don't break?" The short answer is NO, you CAN'T! Not Legally, anyway (if this is a false statement for some of the states, please correct me). Parts are not the only the limiting factor! Vehicle handling, structural design, crash and occupant protection characteristics, to name a few, all play important factors in calculating these specifications as well. It stands to reason, if you're hauling more weight behind you than the vehicle can safely handle and you get into a collision, the vehicle's structural elements and features designed to protect you and your occupants in a crash could become overwhelmed. Generally speaking, vehicles and the parts which comprise them are purposefully engineered to be stronger than needed to allow for emergency situations, unexpected loads, maneuvering and even misuse or degradation over time. Sure, you can add air bags, heavier springs, a heavier class hitch with 'better' weight distribution and sway control, change gear ratios, brakes, wheels, tires and so on! Can it possibly change what your truck could pull or carry? Sure, Possibly. But can that vehicle still operate safely? Can it still maneuver and stop sufficiently? Does it still handle the way it's supposed to, as determined by the manufacturer? With the added weight, can the vehicles safety systems and crumple zones still provide the same level of protection to the occupants in a collision? Does the added weight make you a risk to other drivers on the road? These are the only questions that matter! As far as the law is concerned, it changes nothing. Your trucks capabilities are specified by the vehicle manufacturer when it is built, how it was built, and those are the only numbers that matter. In some states, it's even specified on your Vehicle Registration. So Beware. If you are told by a truck upfitter or choose to take it upon yourself to 'upgrade your vehicle' to haul or carry more weight than specified and something were to happen, you're opening yourself up to a world of liability that you may not be aware of. Officer's have the resources and capabilities to determine your vehicle's specifications with your VIN number should they feel inclined. If you cause an accident with or without injury or death and it's found to be even partially related to operating outside of your vehicle's max operating limits, you're going to have some explaining to do to the police, court or families affected. Not to mention with your insurance company, who can deny you coverage for negligence. Don't put yourself in that position! If you need a truck that can carry or tow more, buy a bigger truck! Period, end. |
