2020RamOwner
Any part numbers for the board? Or are the ones on the 1st or 2nd page it?Only 2 fixes I know of. Replace the whole assembly or open it up and replace the board.
It think the boards are after market from oracleAny part numbers for the board? Or are the ones on the 1st or 2nd page it?
I appreciate it! I wonder if anyone has tried this and its fixed the issue.It think the boards are after market from oracle
ORACLE Lighting 2019-2024 Ram 1500 RGBW+A Headlight DRL Upgrade Kit - LED Projector HeadlightsColorSHIFT - w/BC2 Controller
Featuring our new high-performance RGB+W chips, this new kit allows you to utilize the existing DRL feature on your Ram LED Projector Headlights and easily convert it to Color-Changing DRLs while maintaining a true White DRL.These replacement boards feature our traditional RGB ColorSHIFT®...www.oraclelights.com
I’m sure it’s been done. It removes and replaces the oem circuit boards that control the accent lightingI appreciate it! I wonder if anyone has tried this and its fixed the issue.
I just might be the first. I appreciate it!I’m sure it’s been done. It removes and replaces the oem circuit boards that control the accent lighting
I personally haven’t seen anyone in here that has done it though
heck yea! if you do take pics and update us please! good luckI just might be the first. I appreciate it!
Why would they need to hold it? Just bring it back to get swapped out after the part arrives.Add another one to the list. I have 19 limited. Im calling the dealership to schedule a check soon. For those who got them covered under warranty, how long do they usually need to hold the car for replacement?
Agreed, I wouldn’t let them hold my truck for a headlight replacement.Why would they need to hold it? Just bring it back to get swapped out after the part arrives.
So I watched the video and it turns out I will not be attempting this. I don't care to disassemble the whole headlight and glue it back together. Ill likely have to just buy the new assembly which I am ok with as I plan on keeping this truck for a while. Love everything about it.heck yea! if you do take pics and update us please! good luck
I think the hybrid battery has it's own warranty.I have had my 2024 for just over a week and the 2 items (I read the fine print) that the extended warranty doesn't cover are the Headlights and the Hybrid Battery pack. I still thought the extended warranty to 6 years and 100K was worth it even without those two items.
I am definitely happier with my 2024 than my 2019 and I can tell that they refined the 5th gen for sure over time.
They should have. I would fight it. It's an LED assembly, not a bulb.I had this issue on my 19 while still under factory warranty and dealership said headlights were not covered.
Check this post of mine from May 2022 while still under 3/36. Headlight was replaced under warranty which didn't fix the problem. But they left it in and fixed the real problem which was the body module. So headlight WAS covered in my case.I had this issue on my 19 while still under factory warranty and dealership said headlights were not covered.
Sounds like you have the gremlin my 2019 does. Remote start when it’s below 25 degrees and all of the cameras have pixilation patches but it only does it with remote start.I have determined that if I start my truck from inside the vehicle by physically pressing the button, I dont have any issue with my accent lights coming on. Typically, I will remote start while im walking to my vehicle and thats when I notice the bottom accent light on my driver side not turning on. Seems buggy but a cheap fix, for now..
I've gone back and forth and just think its on its way out. It will come on when it wants to. I check every morning on my way to work as I can see the reflection in a glass window coming out of my garage. Ill go run errands and will work when first started before leaving then ill park it and start it up after stopping somewhere and it wont be on. Just a headache at this point knowing I have to spend over $800 to replace it.Sounds like you have the gremlin my 2019 does. Remote start when it’s below 25 degrees and all of the cameras have pixilation patches but it only does it with remote start.
Agreed! It looks silly as hell one working especially on a limited you expect better!I've gone back and forth and just think its on its way out. It will come on when it wants to. I check every morning on my way to work as I can see the reflection in a glass window coming out of my garage. Ill go run errands and will work when first started before leaving then ill park it and start it up after stopping somewhere and it wont be on. Just a headache at this point knowing I have to spend over $800 to replace it.
