1BADRAMLIMITED
On your setup what are u running? Amber(outer) pair flood and middle pods driving pattern or spot?Hey guys thanks so much for showing interest! I’m really excited to release this kit! It’s designed to work with *most* 3 inch pods on the market! I say *most* because once you start diving into the specs on many of the lights on the market you’ll find that they say 3” but that could mean anything from 2.8” all the way up to like 3.5” depending on the light! The largest lights I have confirmed have been Diode Dynamics SS3s. I bought them to be able to test fit and they look great in the grille but they’ll require a separate bracket for each light because the ones that DD supplies won’t work with how the lights need to be mounted with my kit. So plan on DD specific kits coming about a month later than the Baja kit. Other lights like Auxbeam or some knockoff lights also work! As long as they have a diameter of about 3.2 inches or less they should work however I can only guarantee what I’ve personally tried, which is Baja Designs, Diode Dynamics, Auxbeam, and a knock off set of BD. That being said, the kit is certainly optimized for Baja Designs lights and it will look the most flush/factory with BD lights. As far as adjustment goes, yes the mount itself has vertical adjustment! I designed it to where the lights are perfectly flush and have what I consider to be the optimal angle for light output, but if you’d like to adjust it small adjustments are possible with keeping everything fairly flush, while large adjustments may require slight modification. I don’t see this being an issue though. The mount has some horizontal adjustment to center the lights in the holes, but you can’t really adjust the angle of the lights. The mount fits the factory curve of the grille 100% perfectly, so your lights will follow the curve of the grille and give you a better spread of light than a standard straight light bar
		 , maybe you can also work with BD for some discounts I'm sure allot more orders will come.
, maybe you can also work with BD for some discounts I'm sure allot more orders will come. full bolt on, no drilling/cutting. Comes with the grille replacement and laser cut + powdercoated brackets. It fits 5 lights. That second pic was just an experiment with 6 but I decided to stick with 5. Preorder price of $174.95 with free shipping too. Just throwing it out there
