How to delete the active air dam?
“Additional benefit” is synonymous with side effect. There are good side effects and bad side effects. Obviously, this would be a good side effect. But not its main purpose. That was stated in the first paragraph highlighted.
On a side note, shouldn’t a moderator help enhance forum users experience positively instead of driving users away from using this forum? It’s a rhetorical question. No need answer.
The fact that is says it keeps the shutters closed longer to aid in engine warm up makes it a feature, not a side effect. I'm not arguing the primary function is aerodynamics.
Another Money Pit
WI
Since we are off topic anyways how is your UCA doing with the 5100"s. ( factory still correct?)
Canada 🇨🇦
Hi Mike ! Just unplugged mine and the code is there. Should I try to erase the code? It the problem might be the AGS ?
Thanks.
I doubt there are any videos out there for such a simple job. Just unbolt it, then unplug the connector and tape it up out of the way. I've removed 3 of them and haven't seen any codes thrown.
Mike m
mikeru82
The Palouse
Thanks.
Mike m
Hi yourself Mike. :cool: Are you saying you read a stored code or are you saying you have a CEL? From what people have posted over the years, removing the AAD will throw a code. But it shouldn't throw a CEL. I've never put a code reader on any or our trucks so I wasn't aware that there may be a code stored because of the AAD removal. Try clearing and see if your CEL comes on.
theblet
Thanks.
Mike m
You’ll have to clear the cel after unplugging. There will still be a code stored in the computer, but the cel won’t come back.
Canada 🇨🇦
It was stored, and deleted it. 🤞🏻 it won’t come back !
Paulie T
Removed my air dam and active air dam today and man it looks so much better. Wish I would have done it sooner.
I wanted to remove the shutters also but was limited on time. Started to get it apart but the stupid flares were giving me a hard time and didn’t want to rush then end up breaking something. So maybe next weekend
theblet
Oh !! Sneaky code ! I’ll keep an eye out ! Thx
It’s no big deal. The soft code doesn’t hurt anything. It’ll stay there indefinitely unless you remove the feature from the truck using alpha or jscan
I used alfaObd to turn off the AAD, and still have the soft code
jmr
St. Louis, MO
Me too I deleted AAD in alfaOdb and still got a code sent to the RAM app. I unbolted the air dam portion of the AAD bar and put it back on and no code is being sent to the RAM app.
I tried to separate the bar from the AAD motor by drilling out the indentation on the AAD bar but it would not separate. For now I'm running the AAD without the air dam part.
theblet
hmmm. Would have thought removing it from the computer would also clear the soft code. It must be provisioned in a place we can’t get to
rs2433
I took a hacksaw to mine to get rid of the cross bar. I also tried removing the bolt that held the arms together for the actuator and that threw a code too. I have just the actuator there connected and no codes for 3,000 ish miles
jmr
St. Louis, MO
I drilled 3 - 3/16" holes in the AAD shaft and separated it from the AAD motor. Then bolted it back onto the 2 studs and attached the electric connection. No soft codes and the AAD is mostly gone except for the motor.
wswram1500
2020 Ram Laramie/5.7 Truck just died sitting in driveway. Had to have it towed to dealer. $1200.00 for a computer module later, got truck back, throwing a CEL code telling me active air dam is broke. Can I just remove it. If so how does the connector come off? Will try disconnecting first to see if CEL goes away. Thanks.
Just standard automotive connector. Nothing special. You can try unplugging it, clear the CEL and see what it does. If light stays off then remove the AAD and bag up the connector and tie it out of the way
wswram1500
Excuse my stupidity but dont want to break anything. Picture of plug going to motor is attached. Do I push , pull pry the white tab??
