This was when I was putting them on.Got a daytime pic of the strip on the running boards?
nicely done. Can’t wait to do my grill lights. What did you tap into to switch them?Thought this was pretty cool. I think I’m about done adding lights to my truck now. At least for a few days anyways lol.
That Sam’s trailer parking lamp fuse under the hood. I think it’s F12. But just using that as the trigger wire for a relay. That makes it so the amber lights only come on when I have my headlights on, I didn’t want them on as DRLs.nicely done. Can’t wait to do my grill lights. What did you tap into to switch them?
Very cool. Did you just put the wire under the fuse?That Sam’s trailer parking lamp fuse under the hood. I think it’s F12. But just using that as the trigger wire for a relay. That makes it so the amber lights only come on when I have my headlights on, I didn’t want them on as DRLs.
Ya, same as my grille lights. I have these and those amber grille lights on the same relay. The left leg of the fuse spot, as you're looking down at it with the fuse pulled, is the switched side. So just expose enough of your wire to tuck down in there next to the pole of the position, then push the fuse back down into position just til it's snug. I'm using just a 20g wire since it doesn't take much power at all to trigger the relay.Very cool. Did you just put the wire under the fuse?
