Welcome to the forum.
A bit more info on your Limited would help, also.
Air ride, non air, ORP, non-ORP. 20’s or 22’s…? How many miles on this 2021?
Spacers are cheaper, and serve the same purpose. For your use, it may be a practical option. There are many forum members who are using spacers and are completely happy with them.
Struts will provide a factory like ride with adjustable heights, should you go that route.
From using your old springs to full spring and strut assemblies, many options to consider. It’s all about how much coin you’re willing to dump into it.
Full kits will provide drop brackets for your differential so you can maintain that factory like ride and keep your driveline geometry in check with the additional lift. The good kits will be upwards of $2k before install. A decent 3.5 will start from $900 and up. And finding a good shop to do it all is crucial, and pricey. If your mechanically inclined, this forum will be a huge help in your endeavors. We have no problem helping you spend your money…
A very important thing to know about lifting your truck is that you are now putting added stress on any factory components left behind. Premature wear can/may set in. If your truck has a good amount of miles on it, then swapping out to new parts may not be a bad idea. But again, it’s all about what your willing to invest in it. My opinion is, go cheap, pay later.
As for me, I have an ORP truck, but there is really nothing left from the off road package on my truck. I’ve replaced all of the springs and front struts and rear shocks just to achieve a minor .5 lift in back and a level up front. Am a couple thousand invested into my suspension, but am very happy with my set up.
Don’t off road as much, but am comfortable knowing that I can should I need to.
You picked a great first truck. May you avoid most if not all of the funky quirks that come with owning one, lol.
Do a lot of searching on this forum and you will find a buttload of info.
Please post some pics and more info on your new ride. Congrats and enjoy
