Toperz
I have 21Ram 1500 Bighorn. When I was doing 360view same time I did passive entry so I've changed wiring in doors. I didn't change door modules because it was same as for Limited(got Limited mirrors with camera), rest of parts(most of them) I've used from the list above.What Ram 1500 do you have? What have you done in regards to 360 Surround Camera System, Adaptive and Lane Assist?
Now as for Adaptive Cruise and Lane Assist:
@Piotr_Rebel said that you will not need DASM(Drivers Assistance System Module) for 360view which is correct if you do not plan to add ACC or LA or Forward Collision Warning. But if you do and your truck was not equipped from factory with any of those features then you will need to get DASM+new windsheild+new rear view mirror(not sure about mirror).
As for parts you may have to double or even triple check part# if they gonna work with 22-up. I know for sure that radio(Uconnect 5) is changed.
Then follow @vincentw56 thread and @Piotr_Rebel install plus search forums and ask questions and you should be fine.
@Jimmy07 makes harnesses(excellent quality) if you need.
My truck came with every safety feature I could add so DASM was not required.
