Ramroo
- Jul 1, 2018
I specifically said "... within the truck's weight specs". I would tow any distance with a trailer that is within my trucks weight specs. If the OP needs to tow heavier than a 3.21 is rated for, then he should not buy a 3.21.
Actually, that is false. It is not debatable at all. I said what I would do. How can you debate what I would do?
I have had gas and diesel pickup trucks in half ton and 3/4 ton configs, and diesel in 1 ton config.
I learned enough about towing in all those different types of trucks to know that if *I* were towing heavy enough and often enough to think I actually needed 3.92 gears (in a half ton, gas engine truck), then *I* would get a 2500 with a Cummins.
That is a fact. There is no debate to be had.
A 5th Gen Hemi with 3.21 gearing has an 8-speed tranny and is a very capable truck, including for towing. If it won't tow something because it's too heavy (for that truck and config) and I intend to tow that thing often (all, as I said in my previous post), then *I* would buy a 2500 with a Cummins.
Towing specs are irrelevant for most of our optioned trucks. Sure is for mine.
Some need to look beyond towing numbers and look at payload / GVWR and do some reasoning on what their truck is really capable of.
And.
Pay for a hole in the roof. Oh hell no.
