AnthonyRI
Well, hopefully.I can order a TRX, how bout them apples?
It's already been announced the TRX is returning for 2024Well, hopefully.
Read this, it explains why its to early for EV trucks. Man forced to ditch Ford EV truck during family road trip to Chicago: ‘biggest scam of modern times’
Not everyone needs to upgrade their home electrical. Usually only older houses. No need to add a charging station at your place if employment, unless it's far enough away you would need to top off the charge to make it home, in which case an EV probably int the best option for you.NThe fact you have to upgrade your home electrical service, and then pay to add charging stations where you live and work is beyond the advantage to cost. Keep in mind when there are more EV's on the road, the harder it will be to charge them when traveling and the rates will be higher than if you filled your tank every 500 miles. Then figure in the EV fires that spontaneously ignite, no matter where its located. You can google that and and be surprised with the countless stories you'll load. China is claiming that they have the largest registered EV's in the world, google that too and see fields of rotting EV's, that have been sold and registered.
Just had a charging e-bike burn down a house locally. Fire spread so fast the fire department couldn’t save the structure. That was a battery the size of a small brick. Can’t imagine these huge EV batteries.I don't think there are more EV fires, but they there are it's really hard to put them out. Takes hours upon hours.
Yup. EVs have high voltage, high amps, and huge batteries. When something shorts out its a disaster. Also, if you get in a wreck in one, don't touch anything metal just in case. Instant electrocution if there's current in the chassis.Just had a charging e-bike burn down a house locally. Fire spread so fast the fire department couldn’t save the structure. That was a battery the size of a small brick. Can’t imagine these huge EV batteries.
The fire would have spresd that fast no matter what the ignition source. And all those cheaper e-bikes or hover boards or anything like that come with warnings to not leave them plugged in after reaching full charge.Just had a charging e-bike burn down a house locally. Fire spread so fast the fire department couldn’t save the structure. That was a battery the size of a small brick. Can’t imagine these huge EV batteries.
That’s common sense. Unfortunately that’s far too uncommon these days.The fire would have spresd that fast no matter what the ignition source. And all those cheaper e-bikes or hover boards or anything like that come with warnings to not leave them plugged in after reaching full charge.
ICE vehicles have batteries. And they catch fire more often than EVs. Even when parked in people's garagesThat’s common sense. Unfortunately that’s far too uncommon these days.
My point was if it has a battery the risk is there. I regular pedal bike doesn’t start on fire. The true test will be as these EV’s start aging. Just like anything that’s when the issues start. Not a big enough test sample right now.
And those fires are easy to put out compared to lithium ion batteries.ICE vehicles have batteries. And they catch fire more often than EVs. Even when parked in people's garages
Most new houses, as within the last 20+ years, have 240 "service" to the house, and any house with electric ranges or furnaces already have 240v service. It's just a matter of adding another circuit from fuse panel to the charging station. I believe Tesla, at least they used to, included the installation of the home charger in the purchase of the car.I see some silly stuff continuing in this thread.
"More gas cars catch fire than EV cars." That's because there are exponentially more gas cars on the roads. But if we look at the RATE of fires it's a different story. We've seen EVERYTHING that uses a battery catch fire. Phones, cars, toys, heck even a lawn mower that was ironically being demoed at a trade show caught fire and they pushed it outside as fast as possible to keep from burning down the convention center. High voltage is ALWAYS going to be a problem. I don't see that as something technology will fix. You play with fire you're going to eventually get burned.
"You don't need to update household electric service." Nope, sure don't.....as long as you've got a day or two to charge your truck so you can drive it again. But if you want an electrician to come in and install 240v service safely, which may also require some updates to your fuse panel and new wiring into your garage, you're looking at a large cost. MOST people will end up paying to have this done as I have not seen one single house built new in recent years that has 240v service by default.
And when an EV catches fire it's not the same. These battery packs burn at alarmingly high temperatures and are notoriously difficult for fire fighters to extinguish. In fact, where I live they usually don't even try unless there are occupants still inside.
Putting out a fully engulfed house fire takes the same amount of effort, no matter what the ignition source. And whether it's an EV or a ICE vehicle, they are both total losses after a fire. Doesn't matter how hot they burn or how hard it is to put them outAnd those fires are easy to put out compared to lithium ion batteries.
