2023 Ram MPG Upgrades - Hemi E-torque
theblet
I say 55 mph is highway speed. Maybe I’m used to this because every speedometer on every vehicle had it clearly marked years ago.
jl13
boyle heights, CA
Buy a Peddle Commander and drive every day in Eco mode.😆
I tried that and my mileage dramatically improved by 3-4 mpg but felt like I was driving a 4 cyl due to so much less accelerator response. That few day experiment couldn’t end quick enough. I like the gas peddle too much.
This one is way cheaper
Ramroo
Unfortunately for us the speed limit here is 100 km/h or 62 mph. If I was doing 75+ (120+ km/h) tickets would start to pile up. :)
Taller gears would help if you don't need/want towing or cargo capability.
But then I have to question why buy a full size pickup if you don't need the cargo/towing capability?
I bought the RAM for it's capabilities, not for a daily driver to work and back.
Yeah I get that...we're paying over $6 a gallon here too. :(
My truck is 3.21 and I use my truck to haul and tow heavy all the time with farm stuff at long distances with hills. Maybe more than you.
I sought out and ordered a 3.21 over my past 3.92 1/2 ton. I do a lot of the hauling and towing on the expressway also. It works great, better mileage, about 400 rpm less at 70+ mph in 8th gear in comparison.
So, I think there is a misconception that you have that only a 3.92 can be used “ if you need hauling/ towing capabilities“. You run out of payload capabilities far sooner than needing the shorter gears IMO.
I have used HD trucks mainly in the past for what I do, but I thought I would try the 1/2 tons.
I still use a 3/4, looking for a 1 ton for equipment, but the 3.21 1/2 ton is great for comfort, zipping around, long family trips, with descent hauling and towing.
Will probably always have a 1/2 ton, and it will always be a 3.21. Same capability in my mind, with better mileage.
23RAM
Canada
No misconceptions...3.92 is required for trailering over about 8k. I wanted 3.92 for the max capability knowing I would tow 8.5k occasionally.
3.92 gearing gives you about 3,000 lbs more towing capacity with the same truck setup over 3.21. I tow a 5k trailer regularly, but I've towed up to 8.5k. With 3.21 gearing it would be over the SAE J2807 limit by a few hundred pounds. If you will never need that higher capability, then 3.21 is the better choice.
Oddly enough, RAM promotes the E-Torque system as being more capable, when in fact the regular 5.7L tows over 100 lbs more and has 70 lbs more payload capability with the same truck configuration. That wasn't a factor in my decision - it was the cost of E-Torque over fuel savings - it wouldn't pay for itself over the life of the truck so I didn't want it.
Ramroo
The towing numbers are deceiving IMO. For these 1/2 tons, the payload is what is limiting in all cases for what I do.
I would not personally tow 8,000+ lbs in these 1/2 tons. I would use a 1 ton.
kdoublep
USA
Installation mg performance enhancing parts isn’t going to increase mpg. That’s counterintuitive.
The only thing you can do it baby it, stay out the city, don’t remote start or idle, set the cruise when you can, and keep it 55mph and under.
That's no fun! 17 mpg on computer unless I drive hwy.
Trooper4
Ellensburg, Washington
Every truck is different, and everyone's opinion is different. We all picked for a reason, and we all drive differently, in different terrains, and in different traffic situations. Anyone who compares one truck/car to another has an id10t problem. NO amount of BS on any forum is going to change an opinion. You like yours, he likes his, and y'all need to learn that if we all were the same we'd be like the guy next to you, and he's an idiot.🤪
23RAM
Canada
With 3.21 gears, I agree. But my 3.92 hauls 8.5k very well. Pulling the 5k boat I can barely tell it's back there. A friend uses his 2019 RAM to haul his 10k cabin cruiser every weekend and no complaints in 4 years. The SAE J2807 standard is actually pretty rigorous and pushes test vehicles hard. Most people will never be in those situations so I'd expect no issues hauling up to rated amounts.
BowDown
Frisco TX
Pretty sure he was referring to safety when he spoke about the 1500/3.21/3.92 towing weight.
My 3.21's towed this all steel Max D trailer equipped with air ride, electric trailer brakes, Air compressor, two batteries, winch and power trailer tongue jack. It weighs 5500lbs by itself and had a 3000lb car on it.
Could I tow it? Yes, no issues. Would I want to tow that much weight with a 1500 regularly? F no and let me reiterate, F NO.
The 1500 doesn't have enough truck for that much weight, the rear gears played zero role in my discomfort towing that much weight safely. If I towed this kinda weight with any regularity, I'd have a 2500 or 3500
Ramroo
These trucks can tow a lot. Rated amounts are certainly impressive.
I just cant get close to the rated tow amounts if I honor the payload numbers. My truck has low payload numbers, and none have high numbers.
Its good it works for you.
BowDown
Frisco TX
Yep and mine has one of the higher payload amounts I've seen for a limited and its only 128x or 138x lbs. No way Id tow 10-11K with these trucks. The guy that owns the trailer in my pic above even went from a F250 to a F350 for that reason and he drives trucks for a living, owns a dump truck business with ~15 of trucks
He didn't like the way his F250 felt with 10K lbs
Ramroo
Agreed.
Safely and comfortably.
You’re only as good as your last mistake. I’ve made many.
BowDown
Frisco TX
Agreed.
100%, sad thing is it doesn't even take you making the mistake; with the idiots we share the road with and that much weight, all it takes is one mistake on anyone's part. I found myself damn near driving backwards when I towed that trailer with the car on it. Every time someone changed lanes in front of me, it was back up another 150'.
YouTube is full of videos of too much load and too little of truck
Ramroo
I personally don’t know why people get a 3/4 vs 1 ton.
Some say comfort. I say Bologna.
I‘ve already made that mistake.
RAM_Davis
Pretty silly to imply that 3.21 gears aren't capable.
Only trucks with 8 foot beds are REAL trucks. Only HD/2500/Diesel/8 foot beds/4.10 gears/4x4/etc etc are REAL trucks... whatever
23RAM
Canada
First post is to insult people? Nice.
And who said 3.21 wasn't capable? They're rated up to about 8k or so towing, and if you're never going to get close to that, then 3.21 is a good choice. It's a poor choice for my needs.
Maybe you shouldn't assume.
