Suspension Maxx End Links
Crows foot and some extension is as close as I could get without buying more tools 🤣😭
Well, went ahead and did some trouble shooting. Took the end links off completely and pulled out of my garage. Turned right and still heard the clunk. I’m thinking at this point it’s probably not the sway bar bushings I replaced nor is it the end links. Ive been reading that some are having “issues” with steering and or components of steering. Popped the hood and shook my steering column a little. It was just the slightest bit loose to where I could move it a bit. Is there supposed to be any play at all in the steering column?
I'd probably start looking at parts of the BDS kit.
I have a 2022 ram 1500 with 3.5 ready lift with bilstien 5100 set on 5, doesn't drive great, will these help, also have bilstiens on tge rear with 2 inch spacer that came with kit, I just ordered hellwig swaybar with adjustable endlinks for the rear, just hoping these would solve front steering angles
not my area of expertise but I can say that the hellwig I have in the rear is amazing. I have considered one for the front just because I can. I suspect you will be pleased buy it. I just this week added core 4x4 endlinks with the appropriate height for my rear end lift and they helped make the sway bare evident again after the height
They won't help for what you want. And why did you combine ready lift with the Bilstien lift?
Anyone have any problems with the suspensionmaxx end links rubbing or grinding when turning close to full lock? I have had some grinding noise when making slow turns at full lock or close to full lock since i have installed them
No are you sure it's not just the knuckle stops against the control arm? It's never good to make turns at full lock.
