| 1000 rpm: | 262.2 Nm / 193.4 lb-ft / 27.5 kW / 37.3 PS / 36.8 hp |
| 1100 rpm: | 298 Nm / 219.8 lb-ft / 34.3 kW / 46.7 PS / 46 hp |
| 1200 rpm: | 327.8 Nm / 241.7 lb-ft / 41.2 kW / 56 PS / 55.2 hp |
| 1300 rpm: | 353 Nm / 260.3 lb-ft / 48.1 kW / 65.4 PS / 64.4 hp |
| 1400 rpm: | 374.6 Nm / 276.3 lb-ft / 54.9 kW / 74.7 PS / 73.6 hp |
| 1500 rpm: | 393.3 Nm / 290 lb-ft / 61.8 kW / 84 PS / 82.8 hp |
| 1600 rpm: | 409.7 Nm / 302.1 lb-ft / 68.6 kW / 93.4 PS / 92 hp |
| 1700 rpm: | 424.2 Nm / 312.8 lb-ft / 75.5 kW / 102.7 PS / 101.2 hp |
| 1800 rpm: | 437.1 Nm / 322.3 lb-ft / 82.4 kW / 112.1 PS / 110.4 hp |
| 1900 rpm: | 448.6 Nm / 330.8 lb-ft / 89.3 kW / 121.4 PS / 119.6 hp |
| 2000 rpm: | 458.9 Nm / 338.4 lb-ft / 96.1 kW / 130.7 PS / 128.8 hp |
| 2100 rpm: | 468.3 Nm / 345.4 lb-ft / 103 kW / 140.1 PS / 138 hp |
| 2200 rpm: | 476.8 Nm / 351.6 lb-ft / 109.9 kW / 149.4 PS / 147.2 hp |
| 2300 rpm: | 484.6 Nm / 357.4 lb-ft / 116.7 kW / 158.7 PS / 156.4 hp |
| 2400 rpm: | 491.7 Nm / 362.6 lb-ft / 123.6 kW / 168.1 PS / 165.6 hp |
| 2500 rpm: | 498.2 Nm / 367.4 lb-ft / 130.4 kW / 177.4 PS / 174.8 hp |
| 2600 rpm: | 504.3 Nm / 371.9 lb-ft / 137.3 kW / 186.7 PS / 184 hp |
| 2700 rpm: | 509.9 Nm / 376 lb-ft / 144.2 kW / 196.1 PS / 193.2 hp |
| 2800 rpm: | 515.1 Nm / 379.9 lb-ft / 151 kW / 205.4 PS / 202.4 hp |
| 2900 rpm: | 519.9 Nm / 383.4 lb-ft / 157.9 kW / 214.7 PS / 211.6 hp |
| 3000 rpm: | 524.5 Nm / 386.8 lb-ft / 164.8 kW / 224.1 PS / 220.8 hp |
| 3100 rpm: | 528.7 Nm / 389.9 lb-ft / 171.6 kW / 233.4 PS / 230 hp |
| 3200 rpm: | 532.7 Nm / 392.8 lb-ft / 178.5 kW / 242.8 PS / 239.2 hp |
| 3300 rpm: | 536.4 Nm / 395.6 lb-ft / 185.4 kW / 252.1 PS / 248.4 hp |
| 3400 rpm: | 539.9 Nm / 398.2 lb-ft / 192.2 kW / 261.4 PS / 257.6 hp |
| 3500 rpm: | 543.2 Nm / 400.6 lb-ft / 199.1 kW / 270.8 PS / 266.8 hp |
| 3600 rpm: | 546.3 Nm / 402.9 lb-ft / 206 kW / 280.1 PS / 276 hp |
| 3700 rpm: | 549.3 Nm / 405.1 lb-ft / 212.8 kW / 289.5 PS / 285.2 hp |
| 3800 rpm: | 552.1 Nm / 407.2 lb-ft / 219.7 kW / 298.8 PS / 294.4 hp |
| 3900 rpm: | 554.7 Nm / 409.1 lb-ft / 226.6 kW / 308.1 PS / 303.6 hp |
| 4000 rpm: | 555.9 Nm / 410 lb-ft / 232.9 kW / 316.7 PS / 312 hp |
| 4100 rpm: | 555.5 Nm / 409.7 lb-ft / 238.5 kW / 324.4 PS / 319.6 hp |
| 4200 rpm: | 554.6 Nm / 409 lb-ft / 243.9 kW / 331.7 PS / 326.9 hp |
| 4300 rpm: | 553.3 Nm / 408 lb-ft / 249.2 kW / 338.9 PS / 333.9 hp |
| 4400 rpm: | 551.6 Nm / 406.8 lb-ft / 254.2 kW / 345.7 PS / 340.6 hp |
| 4500 rpm: | 549.4 Nm / 405.2 lb-ft / 258.9 kW / 352.1 PS / 346.9 hp |
| 4600 rpm: | 546.7 Nm / 403.2 lb-ft / 263.4 kW / 358.2 PS / 352.9 hp |
| 4700 rpm: | 543.6 Nm / 400.9 lb-ft / 267.6 kW / 363.9 PS / 358.5 hp |
| 4800 rpm: | 540.1 Nm / 398.3 lb-ft / 271.5 kW / 369.2 PS / 363.8 hp |
| 4900 rpm: | 536.2 Nm / 395.4 lb-ft / 275.1 kW / 374.2 PS / 368.7 hp |
| 5000 rpm: | 531.8 Nm / 392.2 lb-ft / 278.5 kW / 378.7 PS / 373.1 hp |
| 5100 rpm: | 527 Nm / 388.6 lb-ft / 281.5 kW / 382.8 PS / 377.2 hp |
| 5200 rpm: | 521.7 Nm / 384.7 lb-ft / 284.1 kW / 386.4 PS / 380.7 hp |
| 5300 rpm: | 516 Nm / 380.5 lb-ft / 286.4 kW / 389.5 PS / 383.8 hp |
| 5400 rpm: | 509.8 Nm / 376 lb-ft / 288.3 kW / 392.1 PS / 386.3 hp |
| 5500 rpm: | 503.2 Nm / 371.1 lb-ft / 289.8 kW / 394.2 PS / 388.4 hp |
| 5600 rpm: | 496.2 Nm / 365.9 lb-ft / 291 kW / 395.8 PS / 389.9 hp |
| 5700 rpm: | 485.6 Nm / 358.1 lb-ft / 289.9 kW / 394.2 PS / 388.4 hp |
| 5800 rpm: | 471.4 Nm / 347.6 lb-ft / 286.3 kW / 389.4 PS / 383.7 hp |
