6of36
You have the redesigned system already.What is the tsb, and how much do they charge?
I was going to work on this myself, but just noticed in the TSB, the evaporator core gets replaced, and I don't have recovery equipment. I'll check with some local shops first, then if I get desperate, might try Ramcares and a dealership, (which I'm not excited about). But for now with hot weather and no need for a heater, I'll just leave the hack valve closed.The TSB makes a world of difference. There's literally no temp difference now with my hack opened or closed. Just sucks that you have to pay for it. Maybe try to get a good will repair from ramcares since it’s a design flaw and not just a failed part.
In my case, I bought the truck used during winter. Didn’t know how bad the AC would suck until about June. By then the TSB was out. So I made sure to get it done before the 3 yr 36k warranty was up. Others may have bought theirs with no factory warranty. Hard to say.My opinion won't be popular, but with 2024s starting in less than a week, people are talking about 5 model year old trucks. Why didn't you take them in 2 years ago, when they were under warranty? It was acceptable til now? If the truck was in for a complaint about it, while still under warranty, then maybe you could use that, for a good will repair, since the problem was there. But why would anyone expect any corporation to fix anything for free, 2 years after a warranty expires?
Using the TSB, the dealer will follow the procedure to change out your HVAC housing to a new design, in which the heater core air doesn’t mix with the evap core air. Here is the TSB for you to reference. Not sure how much they charge, but I think it is over $1000 iirc.
That matte orange is mesmerizing to me. What is clockwork orange? Other than the book/movie (a clockwork orange), I know that. I would love if my truck was orange or yellow-orange.
Yes a reference to the movieThat matte orange is mesmerizing to me. What is clockwork orange? Other than the book/movie (a clockwork orange), I know that. I would love if my truck was orange or yellow-orange.
Oh nice. Does someone have a copy of this TSB?Current TSB is 24-013-21, they've changed more parts, my invoice lists the current parts.
Looks like they've changed the HVAC controller to because mine now operates differently. eTork doesn't engage as frequently or at all with AC on and now the fan speed drops when a text message comes through uconnect
TSB #24-001-20 A/C Fix. Has anyone had it done yet? Plus are you happy with the results?
Could be hard to convince some dealers to perform a good will swap at no charge, since it’s not a recall I would push them since it’s a design flaw by FCA directly, and not a failed part. If no luck, you can always install the hack. Right, I can definitely understand that. I think I'm more...5thgenrams.com
There is the number.
This bulletin supersedes Technical Service Bulletin (TSB) 24-001-20, date of issue November 25, 2020, which should be removed from your files. All revisions are highlighted with **asterisks** and include part number change.
Thanks. I’ll save it for later in case someone needs itThat's the old late 2020 early 2021 TSB. The current TSB is 24-013-21
Edit, here it is, wasn't listed a couple weeks ago but is now
24-013-21 RAM Technical Service Bulletin24-013-21 RAM Manual Steering Technical Service Bulletin
24-013-21 RAM Manual Steering Technical Service Bulletinwww.tsbsearch.com
And this one is already has part supercededs in it. This TSB calls for heater case 68396071AC and distribution case service kit 68396073AB, mine got a newer heater case 68396071AD and distribution case service kit 68396073AC
I just entered a/c TSB, in the search bar, and that came up. Didn't realize there was more than 1.That's the old late 2020 early 2021 TSB. The current TSB is 24-013-21
Me neitherI just entered a/c TSB, in the search bar, and that came up. Didn't realize there was more than 1.
I did the search bar here, not the internet. I just stopped at the first posting I saw TSB for air.I didn't either till I saw my invoice with a different TSB number. I've been curious as to what the updates were
There's 95 pages of TSB
Looks like there's only two for the AC. Seems like you already have to have an idea of the TSB number, that's sites search isn't very helpful
Just picked up the truck from the dealer. They found the blend door actuator was out of calibration. They recalibrated and also vacuumed system, pulling .51 kg, di vacuum test, no leaks and refilled with Freon and added dye. Will check the performance and report back.My air conditioning started to lose performance. I received a UConnect update, as we were driving, the AC got very warm, stopped blowing and then started cooling but didn’t seem to be as cool as before nor the volume of air as strong. I also noticed when I set the AC to AUTO, the fan speed highest setting is 5 or 6. I can change it to 7 but then the AUTO is disabled. I took it to the dealer in Reno and they said there is nothing wrong. I have another appointment for SoCal when I get back this week. The recirculating door also doesn’t always actuate. I pulled the cabin filter and blew it out, it was a bit dirty and the truck is 9 months old and 10,000 miles. I ordered a new Bosch filter which is supposed to arrive today and I’ll replace it for our drive back to SoCal. The temperature out of the center vents was around 50 degrees in recirculating mode. The cabin still takes an extremely long time to cool down.
Good luckJust picked up the truck from the dealer. They found the blend door actuator was out of calibration. They recalibrated and also vacuumed system, pulling .51 kg, di vacuum test, no leaks and refilled with Freon and added dye. Will check the performance and report back.
