2020 Ram Limited front grill warranty replacement (chrome to night edition black question)
Dw1973
My chrome grill on my 2020 Ram limited 1500 is peeling in a few places and will be replaced under warranty. I want to replace it with the black limited night edition grill to break up all the chrome up front. My local dealership does not know if the black limited night edition grill will work on my truck because my truck has a grill module (shutter) and camera surround mount. Anyone out there have a part number for the black limited night edition grill that has a grill module and surround view camera mounts?
That is odd that your dealer told you that. All Ram DTs have Active Grill Shutters. I don't have a Limited so I don't have a part# for you but I'm sure someone here who does will chime in.
I don't know the part number but I have a 2022 Limited black night edition with surround view cameras and the AGS...
Sounds like your dealership is a bit clueless.
You can give them my vin number if you want them to lookup what the part number is: 1C6SRFHT5NN264168
Thank you! Much appreciated.
Ever figure out the limited night edition grill part numbers?
It will work, I did a compete chrome delete and brought every Limited night edition parts for a 2021 ram Limited (black) with Chrome . Helped convert a friends to the night edition. Once done you didn’t know it came from factory with chrome
hood, headlights, taillights, window moulding, door handles, tailgate and all the emblems. He had rims power coated to factory nigh edition color.
There is no powder coat that will match factory night edition Limited rims fyi.
He could of matched them to the Laramie night edition rims (which are completely differnet)
I didn’t say my friends were black but rather the color ram does them which is more of a dark gray and truly black.
And yes they match. The shop we use is the same that repairs the rims when damaged or curb rash for the dealership that I worked at. Not saying anyone is wrong but the color did in fact match other limited trucks that had the factory rims.
My limited rims were done in true black but that was me.
1st picture is his rim
2nd is mine
My former 2020 limited night edition with true black rims after I had them done.
2nd is mine
Yep that's how it looks.
Second one doesn't match factory night edition wheels.
I would say the all black does in fact look way better, but mine from the factory look nothing like yours do now, or what yours on that 2020 look like.
I wish mine came black like you had yours painted to be.
There are also a ton of posts here about the color, which I have the code and paint for which is not black either.
The correct paint code is PNW which as far as all my research and talking to several shops say they can't get or create with a powdercoat, but paint can be ordered for it.
These pictures are all of my truck with everything OEM.
This last picture is from the dealership before I went to go get it, they weren't black then either.
Would you happen to have the part numbers? I don't need the wheels really....I am thinking about lifting the truck so I would just buy 20" aftermarket etc.
In Detroit for work. Will look when I get home Thursday
Or do what I did I found a night edition and order parts for my friends off the vin # as I didn’t have mines yet.
Do you have the Ram Limited Grill part numbers? Mainly upper and lower surround or appliqué
Ik heb mijn limited ( Anniversary) ook alle chroom delen zwart gespoten. Grill, handgrepen zwart metallic en sleepogen en logo's zwart mat. Raamomlijsting hoogglans zwart.
velgen moet ik nog doen. Zal grijs metallic worden.
