Rickyrocket
- May 19, 2020
I have the 3.21s also 5.7 no etorq it tows my 26' tt just fine, getting 9-11 mpg. Trl weights 5600 w 7600 gvw max. probably around 7000 currently.
Here you go.
SAE J2807 Tow Tests - The Standard
Maximum trailer tow ratings have been a bit of a mystery over the years. Manufacturers each had their own somewhat secret ways of determining how much weight thwww.motortrend.com
All modern trucks are tested with the same set of rules, hence they all can and will tow what they are rated to tow safely and securely.
I would suggest to pay a lot of attention to maximum frontal area specs for these Ram 1500 trucks as well as their midsize cousins. I tow a 8.5x20 enclosed trailer set up for camping and hauling two utility ATVs. I do have the 3.21 axle (which SUCKS) and 35" tires which also doesn't help. But the truck struggles and runs in 4th and 5th gear constantly, with 3rd going up hills. I see around 7 MPG if the weather is good. It's miserable. Handling is perfect because I have the Centerline TS hitch. Braking is perfect because 5th Gen trucks have HUGE brakes, plus the trailer has it's own. It's the going and maintaining 55 MPH that sucks. The Hemi drinks fuel like it's sponsored by OPEC.
You're half a foot wider than my RV, little shorter, but I bet mine rides higher. Anyway, I'm a little surprised by your comments, because I can get 8 to 12 MPG (depending on head/tail wind), and normally my truck hunkers down in 6th and just cruises for miles. I use the gear limiter to lock out 7th because it will upshift often enough I just prefer the higher RPMs.
Hills will definitely downshift, just the nature of any N/A gasser.
I'm not sure you're going to find a much better experience in any other N/A gas truck, unless you go super duty with the 7.3 or GM 6.6 but even those will rev higher up.
You should probably just bite the bullet and go for a SO cummins in a 2500. All that sweet low end torque, and even with reduced payload (vs gasser 2500) you'd still end up with several hundred pounds more than your current truck.
Diesel should in theory have slightly lower upkeep costs like gas price and stuff. Weather you do the math and determine how many miles that break even might then I wouldn't know.Personally, I'm shopping 3500 and 4500 trucks. If I'm going to sacrifice a smooth ride and garagability, then I'm going all out so I'll never wish for more capacity ever again.
The question is, a big gas V8 with 4.10/4.30 axle, or a diesel with it's $9k higher price and much higher maintenance costs and it's inability to be worked on at home? Hmmmm......
I have seen people who get turned away at Ram dealerships after buying a diesel too.I like the sound of a gas working hard, that doesn't bother me in the slightest. But I would also enjoy a diesel even more. The main thing that turns me off on diesel is getting stuck with my trailer in some two bit town with no diesel mechanic in sight. Gas mechanics can be found everywhere, but the availability of good diesel mechanics is harder to find and you probably wait longer.
Let us know what you decide on after your research and shopping please.Personally, I'm shopping 3500 and 4500 trucks. If I'm going to sacrifice a smooth ride and garagability, then I'm going all out so I'll never wish for more capacity ever again.
That's the one thing that would keep me out of a 2500 6.4 is the overall gas mileage. My 3500 SO 6.7 crew cab single wheel Ram only averaged around 16 mpg. I really enjoy my 1500 5.7 Big Horn. It's the first V-8 I've owned for about 20 years.I had a 2016 ram 2500 6.4 4.10 gears, awesome truck but got 11 mpg on the highway driving like Granny. totally empty, never towed with it it sucked down that premium quickly.
What's the mpg on the ram 2500 diesel. I keep seeing it actually gets 1 mpg less (highway) than the gasser. I've seen this for the chevy 2500 as well while the ford 2500 diesel gets great mileage compared to it's 2500 gasser. Am I missing something? No way I'd pay 10k more for a diesel to get the same or worse mileage and paying more at the pump. I was thinking the diesels would average around 20 mpg.
And even the 5.7 is recommend to use 89 not 87.The 6.4 is premium only
The math is far more in favour of diesel than most realize. You get hit up front by the initial cost, but you get it back the second you sell it (or a percentage of it based on years you've owned it and been enjoying it all that time).
But it's not always about the math, sometimes you're just willing to pay for that low down effortless torque.
Basically: I'd love to drive a diesel. But I'd rather own a gas.
I also have the 2021 ecoI just traded in a 38’ total length TT for a 31’ that was 2 years newer.
Old camper:
Weight
Dry Weight
6,752 lbs.
Payload Capacity
2,898 lbs.
GVWR
9,650 lbs.
Hitch Weight
850 lbs.
2018 CrossRoads Sunset Trail Super Lite SS336BH specs and literature guide
It accelerated and stopped just fine. Sway got out of control on interstates driving above 65. Not recommended for long hauls, semi’s push it all over the place. Stability control kicked in when I was intentionally pushing it to see the limit at 70-75. It was good for local pulls within 100-200 miles from home.
New camper:
Weight
Dry Weight
5,854 lbs.
Payload Capacity
1,828 lbs.
Hitch Weight
682 lbs.
The smaller one is much more manageable and pulls a lot better. More controlled and doesn’t sway. Weight distribution hitches on both. Id love to upgrade to a 3/4 or 1 ton truck but I can’t bring myself to get rid of a truck that gets 30mpg on its own. I’m impressed I can get 20mpg with the new camper at 60mpg. Hope this helps
I also drive the 2021 1500 DT, EcoDiesel, and i pull a 30 travel trailer / toy hauler. I added the Air lift Model 5000 suspension system, now that I can adjust the sag out of the pull it handles beautifully.I just traded in a 38’ total length TT for a 31’ that was 2 years newer.
Old camper:
Weight
Dry Weight
6,752 lbs.
Payload Capacity
2,898 lbs.
GVWR
9,650 lbs.
Hitch Weight
850 lbs.
New camper:
Weight
Dry Weight
5,854 lbs.
Payload Capacity
1,828 lbs.
Hitch Weight
682 lbs.
No it isn’t. It’s just 87 recommended.No it isn't. It's 87 octane acceptable, 89 recommended just like the 5.7 engine. Most guys run 87.
