Trying to use AlphaOBD to read Radio PIN code (to program new key fob)
Good day to all, today I was trying to program a key on my 2021 Ram 2500 with Alfaobd got my bypass cable, obdmx +.
Dodge / Ram
Ram 2500 (DJ/DR)
Radio Frequency Hub (RFH)
Radio Frequency Hub My2013 + PowerNet
Connect
Select Procedure to Start
Read Pin (Start)
The problem is that it tells me that it is not supported 5 pin digits.
If I go to a dealer and get my 5 Digits can i program the Key.
If someone know when Alfa obd will update to get the 5 digits.
Thank you
You can no longer program your own key fobs
Correct as it's a rolling pin code. Need to have the special tool
I have never tried with Alpha, if you have the current pin code could you still do it?
Dodge / Ram
Ram 2500 (DJ/DR)
Connect
Read Pin (Start)
Thank you
Hello Dear
I am facing the same issue n my 2021 Dodge Charger.
I get the 4 PIN by alfaOBD but when I need to program the new key fob, it's asking me for 5 PIN !
Had you fixed the issue?
I have a fleet of Ram Promaster vans at work ranging from 2016 to 2021/22 that uses the laser cut flip key fobs. We use a mobile locksmith that spent a ton of money to buy the licensing and equipment needed to make the laser cut keys and to program the fobs. I believe he charges us like $250 per fob to make the key and program. It can be done without the dealer but it's very expensive
