2021 Ram 1500 Bighorn Media Hub Replacement
cnewman402
I did not see a HOW TO anywhere for the media hub replacement. Keeping the story short. I bought a 2021 Ram 1500 last week. I found these forums. I have been trolling. I found how to fix it. Ordered the new part number from Mopar Parts. Replaced it. Now I have CarPlay. New part number superseeds other part numbers. Hopefully the transistors have been fixed.
And.... Here we GO!
Pull the radio out towards you. You wont break it. (Great clips Mopar!)
And by bench, I mean cooler, because its on the bench. :)
Reverse order to reinstall.
Note: The 4 screws that are deep.... I used electrical tape and secured the screw to the end of the screwdriver. I struggled with that depth long enough. I had a magnetic screwdriver. They just kept falling off.
Media Hub USB Port - Mopar (68397098AE)​
  • SKU:68397098AE
  • Other Names: Plug
  • Description:
    MEDIA HUB
  • Condition: New
  • Replaces: 68397098AA, 68397098AB, 68397098AC, 68397098AD
Nice write up. Do you have the 3 person front seat?
Here’s my swap on my Ram with the center console, 2 seats up front.
Part #
68397098ae
Follow this vid for removal
When I removed it just the back piece came out, so I reused the face plate from the old one
And.... Here we GO!
  • SKU:68397098AE
  • Other Names: Plug
  • Description:
    MEDIA HUB
  • Condition: New
Thank you for this!
I followed this 2019-2022 Ram 2500 3500 How to Remove Center Console YouTube video and replaced the USB media hub (Media Hub USB Port, Center Console - Mopar (68397098AE)) and now all is working perfectly.
Note it was a little difficult getting the old hub completely removed from the console like forum poster THEBLET mentioned and showed in their pics . I did the same as they did and reused the face plate but all in all it took about an hour to get everything taken apart, replaced, tested and put back.
Special thanks THEBLET to also to everyone in this thread.
2020 Ram 1500 Big Horn
Glad it worked out for you!
And.... Here we GO!
  • SKU:68397098AE
  • Other Names: Plug
  • Description:
    MEDIA HUB
  • Condition: New
Thank you for this only thing I could find on how to change it out just swapped mine out only took 20 minutes
Great write up, thanks!
I swapped out my hub quickly using your post. I still have the same problem, I don't have a data connection just charging capability but at least it was an easy task thanks to your guide.
