What spare parts and fluids do you keep in the truck at all times?
djevox
VP of Creative Thinking
MD
1 qt oil
coolant
air compressor
breaker bar
jump starter (hulkman 6.5 in a vehicle - noco gb40 in the other)
straps and ties downs, along with basic recovery wear
moving blanket
I keep all that stuff except the oil and coolant, and I have diesel, so I keep fuel additive in the truck also.
BowDown
Frisco TX
Dewalt DCF899 Impact Wrench/22mm socket
Dewalt DCC020IB air compressor / Tire plug kit
Rubber kneeling pad/gloves
Battery pack jump starter
Ratchet Straps 2" for cargo
And a few other things ...
When I go on road trips, I do take my kobalt 600ft lbs 1/2" impact gun, lug nut socket and a tire patch kit.
Don't need it but the impact makes short work of lug nuts
biohazard
I got rid of the "full size" temporary spare and replaced it with a real spare tire (found a matching takeoff wheel on ebay).
I also got a bottle jack, but haven't found a good place to put it. The in-floor storage boxes aren't quite big enough, even with the liner removed.
I don't carry and extra fluids or parts with me. It's a new truck and shouldn't have any issues.
Agreed. I'll check fluids before leaving on a trip.
Jako
Borough of Parks
So who wins the
Boy Scout Motto?
Be Prepared!
And with all that "good stuff" who wins the
Boy Scout Slogan?​
Do a Good Turn Daily!
Maybe not daily, but I have jump started a few people, and have pulled someone out of the ditch with my recovery strap. Saving them an expensive tow truck bill because closest tow truck was 45 minutes away. hope to never need the fire extinguisher, first aid kit, or survival kit
So who wins the
Boy Scout Motto?
Be Prepared!
Boy Scout Slogan?​
barrak
CO
I bought an inexpensive Plano 108L trunk from Home Depot which can fit all kinds of knickknacks, including a floor jack at the bottom as long as it's within 30x12 inches. My Arcan 3-ton hybrid fits nicely there. Make sure to get the model with a sealed lid... there are three different lid variations.
Loudram
South Jersey
I keep the basics:
Air compressor (battery powered/12v)
Tire plug kit
Jump box
Multi tool
Ratchet straps
Bungie cords
First aid kit
My cheap OBD2 reader
I really need to find a better jack. One that can pull double duty for both my truck and travel trailer. I'm going to check out the ones mentioned in this thread to start with.
kdoublep
USA
Supplies:
5 gal gas
Cargo net
Ratchet straps
Bed divider
Jumper cables
Socket set
Breaker bar
USB cables
2x4's (you never know)
Defense:
Cold Steel Tanto blade
Cold steel expandable baton
Hellcat 9mm
sharks with laser beams attached to their heads
After reading everyone's lists, I realized I need more stuff. :)
Loudram
South Jersey
I have been thinking about replacing the oem jack many times but I can't remember the last time I had to use a jack on the road. I know when ever that happens I am gonna be cursing at it
thinking about a bottle jack and came across this the other day
Here's basically the same one for cheaper. Same company, weight rating, lift height, and weight. The only difference is the color. I'll probably get it.
Edit: Nevermind, I only have 10 1/2" clearance to my trailer axle. I need a shorter one.
Powerbuilt 3 Ton, Bottle Jack and Jack Stands in One, 6000 Pound All-in-One Car Lift, Heavy Duty Vehicle Unijack, 640912 https://a.co/d/dLUaknx
jl13
boyle heights, CA
Let me put some more crap in my truck so I can win 😆
I'll start by adding some good things from other members' list
1st aid kit
fire extinguisher
gloves - a have several pairs at home that I have purchase or have been given to me that I never remember to use until I hurt myself lol
And forgot I also carry one of those red foldable triangle warning signs that somebody just left around work
jl13
boyle heights, CA
same here, the stuff I carry tends to be use to help others
jl13
boyle heights, CA
Supplies:
5 gal gas
Cargo net
Ratchet straps
Bed divider
Jumper cables
Socket set
Breaker bar
USB cables
Defense:
Hellcat 9mm
I also carry a small block of 2x4
