My 21' 1500 Limited was parked a tad too close to my 5th wheel and I snapped the rear left door handle off.
I read some posts on here helping me figure out how to remove the handle. Also found youtube videos for how to remove the outer sweep/panel. I still can't get to that handle bracket inside the door though!
Question: Anybody on here know the trick for removing the inner panel? It seems to be stuck due to the window / window regulator and the locking door hatch. Do I need to detach the window regulator from the panel or the window from the window regulator? And how?
Edit: Adding emphasis that I already got the handle removed (super easy) -- I need the bracket behind it removed as well!
Here is the parts page/diagram I have been studdying (I need to access part #6):
store.mopar.com
Bonus (Color Matching): I found two left door handles with my color code (PSC) in the 7th and 8th index of the serial code. Using some intuition, I think that the prefix -- 6CV441 -- may be the indicator that it is the chrome version where as -- 6DF95 -- may be the solid paint. Mopar is horrible about leaving clues to this but I was able to find an image of the chrome version with a different color code here.
Rear Door for 2021 Ram 1500 | Mopar eStore
