'21 RAM 1500 eTorque Recall...."Good News"
Scap
Sounds like they disconnected the battery when preforming the recall which is likely why you saw better (fake) MPGs.
No need, they rebooted the PCM. It likely cleared the KAM info as well.
Darksteel165
Massachusetts
Not sure what KAM stands for.
I was just referring to putting the truck back into learning mode for like the transmission and stuff, going to get differnet MPG until the truck settles back in. The recall did change the tune itself so it's normal to see weird numbers while your truck adjusts back to normal.
2001gw
Ocala, FL
I had mine done 5/5, and as of this morning, the fuel usage has settled back down to 18-19mpg indicated which is what it has always indicated. After the update, I did see the 21mpg, but it didn't last more than a couple tanks.
I will say this; after the flash, I don't hear any pinging at WOT. Before the flash it sounded like an old Econoline E-150 with a worn out 351W.
Gee...I hope that's not what is really happening! o_O This morning I zeroed out the MPG and did city driving around town. Probably drove around 60 miles today. I took this photo when I pulled back in my driveway. If it changes back to 18-19 MPG in a couple of weeks I'll be disappointed. I'll let you all know if it does.
Scap
KAM - keep alive memory. (Least that's what Ford calls it).
That is what stores your driving style algorithms.
jessed1
The article linked under the news section lists: PCM calibration software. This makes me wonder if certain driving styles exasperated this issue. My MPG didn't change after, but I also never had an issue with stalling.
6of36
Michigan
When they issue a recall, they have a range of build dates that have reported faults, then extend both ways in case there are some not reported yet, just outside the reported dates. It would be similar to when my 20 had a recall for axles. They had a run of improperly tempered ones. Mine wasn't effected, but was near the date of bad ones.
BowDown
Frisco TX
What were the outside air temps then vs now?
2001gw
Ocala, FL
Well....disappointment has set in. My average MPG has fallen back down to around 18 MPG. It was nice to dream. My neighbor has a Ford with the EcoBoost V6. He says his average around town is 21 to 22.
theblet
If you keep in at 55 and under you can achieve that with out a lot of city driving.
2001gw
Ocala, FL
Not in my truck. On Memorial Day we did a 120 mile round trip mostly on 50 to 60 mph roads and averaged 19.1 MPG.
6of36
Michigan
He lies. My brother had a Ford ecoboost. He was lucky to get that highway. The only time the ecoboost was better, was towing. They lose 1 mpg, while Rams lose 7-8 mpg.
uncc_99xj
Harrisburg, NC
If he has the 2.7, maybe. And that's a big maybe. My 3.5 got 17 average around town, and would get into the low 20's on long highway trips not towing. Towing, it was 10-12 consistently.
6of36
Michigan
It could depend what you tow. Do you tow a big trailer? He only tows a 16' aluminum flat utility trailer, nothing heavy. It didn't drop much with his Ford. But tow a 250 lb empty trailer with a Ram, and mileage cuts in half.
Idahoktm
North Idaho
Oh come on. I pull a 8' utility trailer around town with 500' of cargo and my mileage drops 1-1.5 MPG.
uncc_99xj
Harrisburg, NC
I tow a ~21' car trailer with my Jeep on it to various off road sites around the Southeast and Midwest. Trailer is 1200lbs empty and the Jeep with all my crap in & on it is probably 3500lbs. In 2018 we made a bucket list trip to Moab. NC to UT and back netted 10mpg average for 4,000 miles with my 3.5/10 speed combo over a trip that took two weeks. Everything from the Appalachian mountains, to the flat Midwest, to the Colorado Rockies. We saw all 4 seasons on that trip too. It was 95 when we left NC, and 21 and snowing in Denver on the trip home.
6of36
Michigan
If I haul my 9 ft utility trailer empty, mileage drops at least 7 on a good day.
6of36
Michigan
Lol. Better check the wheel bearings on your trailer.
It's the easiest rolling trailer I have ever seen. I can roll it all the way across the yard by hand. It's wind resistance. I bet if I attached a flag to the back bumper and drove around it would lose 3 mpg.
