That makes sense. Do you use this website?
				Genuine FCA Part # 68474873AA - Wiring. Header. Fits 1500. Ships from Athens Dodge, Athens GA
					www.moparpartssurplus.com
Very informative. Luckily I think there are only three or so harnesses to pick from. Sometimes a leap of faith.
I don’t have the safety package options you have in your Bighorn. Might be rare to find someone who has done this mod with your specific configuration that can explicitly confirm. I’m adding this mod later, but that will not help you as I have the same mirror as the other fellow.
Yes I have been on the parts site and noticed the various build package options are listed for harnesses but alot of text there in the description!
What I did today was get on the dealer inventory site and find a new 2022 1500 with all the options I currently have (and wanted to add), and then called the parts desk at the dealer to see if any of the harnesses on my short list are assigned the VIN.  The descriptions are confusing a little on the website but I found the first paragraph in the description ending with a period before a new line is accurate to the packages, and then all the gobblygook underneath is to be ignored (80% positive on this statement).
I verified the harness for the Limited with the parts desk and then had him double check the other two to see if they are matched the Limited, finding out that they were not.  I then cross referenced my VIN verifying the harness part number to which I observed when pulling the right pillar/panel.  Seems like each harness matches a set of options which makes sense, cheaper harness = less options, expensive harness = more options.  I did some ebay scraping for actual images of the harnesss to compare the connector counts and shapes to see if the various harneses would match, and they all look like the same connectors, just more or less quantity depending on the options it supports.
Here is what I found on the parts site,
four header harnesses, maybe someone can check my work here, Ive been juggling a day job today
Cheapest, just the mirror (25 bucks)
68488876AA - [DIGITAL REARVIEW MIRROR] OR [GNK].
Facebook post above, apparently no lane assist as per the photo (28 bucks)
68488874AA - [DIGITAL REARVIEW MIRROR] OR [GNK], [Rain Sensitive Windshield Wipers] AND/OR [Air Cond ATC w/Dual Zone Control].
My Bighorn with no existing Rain/Humidity sensor, but already has bracket  (36 bucks)
68474872AB - [DIGITAL REARVIEW MIRROR] OR [GNK], [LANE KEEP ASSIST] AND/OR [ADAPTIVE CRUISE CONTROL W/STOP and GO] AND/OR [Full Speed Fwd Collision Warn Plus].
Limited from the dealer Inventory website (49 bucks)
68474873AA -  [DIGITAL REARVIEW MIRROR] OR [GNK], [LANE KEEP ASSIST] AND/OR [ADAPTIVE CRUISE CONTROL W/STOP and GO] AND/OR [Full Speed Fwd Collision Warn Plus], [Rain Sensitive Windshield Wipers], [Air Cond ATC w/Dual Zone Control
So,  I guess adding the sensor to complete my ATC mod, and/or enable Rain sensitive wipers to my specific package would mean I need to add the next level up harness which is
68474873AA, supporting the most options.
I dropped the front headliner via a youtube guide to see the feasability on replacing the harness, took me less than 30 min. Harness even just plugs into a slot in the side panel near the passenger vent. So seems pretty straight forward to swap the harness, add the sensor, and program AlfaOBD.  Easy except I have a light tan headliner so need to have spotless hands for this one, and clean tools.
Hence I ordered the new harness and sensor with a gel pack today, and will see what happens I guess.
