'21 RAM 1500 eTorque Recall...."Good News"
2001gw
Ocala, FL
I've had this truck for 2 years. My average "around town" MPG has always been around 17.8 to 18.2 MPG. Last Monday I had the recall done on the truck (took about 15 minutes). As of today, I am averaging 21 MPG! (y) I do very little highway driving, but I imagine the Highway MPG will be even higher. :)
Mountain Whiskey
It is for the "21 RAM 1500 eTorque. They do an update (Flash) to the ECU. They plug into the OBD2 port and reprogram it.
I understand how a flash update is done. What was the recall for? They don't do recalls just in general and not say what it is being recalled for.
6of36
Michigan
Engines running rich and causing stalling, and that sends bad signal to trans, so it effects shifting. Only certain 21s, and all are Etorques.
CRAIG4FSU
South East USA, Earth
I have seen no gain. Had it done last week. Still avg around 13.5 😢
Was it stalling?
My ‘21 Etorque has stalled on me once when pulling onto a busy road. It was brief and picked right up, but still.
I need this recall and the one for the tailgate checked. I’ll have them check the ******* coolant smell while they have it.
6of36
Michigan
I think it only really changed highway MPG. It changes the shifts. My brother complained since he got his about radical down shifts on slight down hills. I said it's normal, to maintain speed. I thought he was just exaggerating it. He said after the recall it didn't do it any more, and he gained almost 3 MPG highway. He was shocked.
BowDown
Frisco TX
I'd imagine most of the fuel mileage gain was from out leaning the engine. If its was loading up to the point it was stalling, the ecu was dumping a crap-ton of fuel in the cylinders. That alone would make for a huge fuel mileage increase. My other concern would be that the ecu calling for enough fuel to stall the engine is also washing the cylinder walls down. Id change the oil ASAP and see if it smelled like fuel
2001gw
Ocala, FL
I would say you are correct. The recall as I understand it was for too much fuel being delivered to the cylinders (running rich).
jessed1
Mine was performed about 2 weeks ago - very slight change in MPG that I attributed to the switch to the summer blend. Mine never did stall before sooo who knows if it even needed the change? I also had the tailgate recall performed and, for the first time ever, it opened while I was driving :mad:
titan3636
St Augustine FL
Was it stalling?
I had it stall twice over the last year. Both at very low speeds. Glad they finally put out a recall and hopefully it’s a fix.
CRAIG4FSU
Electronic tailgate?
Scap
I had mine done 5/5, and as of this morning, the fuel usage has settled back down to 18-19mpg indicated which is what it has always indicated. After the update, I did see the 21mpg, but it didn't last more than a couple tanks.
I will say this; after the flash, I don't hear any pinging at WOT. Before the flash it sounded like an old Econoline E-150 with a worn out 351W.
Darksteel165
Massachusetts
Sounds like they disconnected the battery when preforming the recall which is likely why you saw better (fake) MPGs.
