U
		User_3336
Guest
My ORIGINAL question was.They are the same thing, tread lightly is an affiliate organization so if you are a member at the $100 or more annual membership they will give you a control number. You have to be a member for a minimum of 30 days before the number is valid.
How are dealers using the control #'s, using the FFP $$$ specifically stated on the POC sheet, then giving a discount below that?.
you have to sign that sheet, with the authorization #, and the POC sheet attached, and the #'s SHOULD be filled in. Are people just signing a blank sheet and the dealer says "They'll fill it in later". Of course, that's upon them if they fudge the #'s not on the buyer.
