Been awhile, and I got a few truck updates I can share. Finally at a comfortable point to share some of the progress made.
1. I managed to get the Auxbeam switch panel install pretty much completed. Few minor details remain, but the bulk of the wiring and cleanup is done. Once I'm satisfied with everything's placement under the hood, I plan to clean up the main feed of wires leading to the fuse panel just a tad more to make it less cluttered looking and also appear more factory like. I'm running 4 out of the 8 switches currently, and that will soon jump up to 6. I haven't moved the rock light wiring over to this panel yet, but hope to get that addressed soon.
Here is the current wiring setup.
- 30A slot 1 - 22" light bar
- 30A slot 2 - A pillar light pods
- 20A slot 1 - Light bar & pods white DRLs
- 20A slot 2 - Light bar & pods amber DRLs
- 10A slot 1 - Rock lights white (not yet hooked up)
- 10A slot 2 - Rock lights amber (not yet hooked up)
- 5A slot 1 - Unused
- 5A slot 2 - Unused
My plan is to move the light bar and pod DRLs down to the 5A's. The DRLs definitely don't need to be on the dedicated 20's, and that will free up the potential to add something there later on down the road. I had the DRL's on the 20's just during my initial testing, and never ended up moving them over.
As far as the switch panel goes, that also needs to find a permanent home. I'm testing out different locations for it in the cab to see what I like most, and so far it has lived on my BulletPoint mount for the last week or two. I like the placement there, but I really don't want to lose the phone holder. I use it regularly. Especially for my work cell phone while traveling for work. I'd like to keep the panel on the driver's side if possible, so looking to test out an A pillar option that someone recently shared with me as well. Will update once everything is completely finalized with all of this.
2. New Light Bar and Pod Lights. I know it seems like I just installed the DV8 pod lights, and well, that is because I did just install them. I wired them up and only ran them for a few weeks. Let me tell you, I was very impressed with the light output on these. No complaints from looks or the function, but being the visual person that I am, I found something I wanted more. That led me to purchasing a new set of lights from Strands Lighting Division. Strands is a Sweden based company, and appears to be a pretty popular choice all over Europe, but I couldn't find much information on them at all here in the States. I actually had to purchase these from a seller in Canada, and have them sent to me down here in Florida. Strands makes numerous variations of lighting solutions, but I went with two products that closely matched what I already had just for simplicity.
The specs on these new lights are considerably better than what I had. I haven't really been able to get out and put them to the test yet, so I cannot completely confirm the claims, but they definitely appear to be brighter. My favorite feature about these is the DRL functionality. These have both white and amber DRL settings. the DRL feature on these new lights are basically an exact match to the Lasfit rock lights, so it does an awesome job at bringing everything together from a visual standpoint.
3. Amp Override Switch - Like mentioned a few posts back, I really only purchased this to fill in the hole from my previous light bar switch that I had drilled into the plastic. Once I removed the RC light bar and installed the new bar to the switch panel, I had no use for the on/off switch that remained next to my headlight dial. I didn't want to leave a useless switch installed, and when I realized a replacement headlight switch bezel would run the same amount almost as the Amp switch, I decided to obviously go with the Amp switch. I was hopeful that everything would fit properly, and I was so shocked to see how cleanly it fit in place. The switch is literally the exact same size as what I had, and it popped right into place. I still need to wire this switch to the Amp controller that sits in the engine bay, but as you may imagine, I'm a little burnt out with wiring projects right now lol. I'm planning on getting this wrapped up in a week or two, and will also drop an update on this once complete.
I've got a few other things in the works, but nothing confirmed or actually purchased at this point so will end this post here for now.
