Rampat
I just leveled my 2021 Rebel and put a set of Toyo Open Country R/T Trail’s in LT295/70R18. 10 ply tire and load rating E. What tire pressure should I be running? The stock Duratrack’s were 55psi front and 45psi rear.
Thank you! Just did the calculator and it came back with 47psi front and 39psi rear.There are calculators online that will tell you what pressure to run with non-stock tires, baed on the stock tire numbers.
Explain this chalk test to me please.Tire pressure will vary based on the tires you are using. There is no one size fits all pressure, or any online calculator that can accurately tell you the correct pressure for your truck. Too many variable from tire construction, vehicle weight, driving style...... The best way is to do the chalk test to find what gives you an even contact patch
www.intercotire.com
I never knew this method such a wealth of knowledge on this website thanks for the share.Using The Chalk Method for Determining PSI | Interco Tire
Using The Chalk Method for Determining PSI - NOTE. This article is posted for reference only. You should always consult with your local tire installation professional(s) when you have questions about your tires.www.intercotire.com
