Correct Tire Pressure?
Rampat
Boca Raton, FL
I just leveled my 2021 Rebel and put a set of Toyo Open Country R/T Trail’s in LT295/70R18. 10 ply tire and load rating E. What tire pressure should I be running? The stock Duratrack’s were 55psi front and 45psi rear.
mikeru82
The Palouse
Your new tires are 1 inch taller than stock but both stock and your new tires are 10 ply. I'd probably stick with the recommended tire pressures of 55 front/45 rear.
Reverse
There are calculators online that will tell you what pressure to run with non-stock tires, baed on the stock tire numbers.
Tire pressure will vary based on the tires you are using. There is no one size fits all pressure, or any online calculator that can accurately tell you the correct pressure for your truck. Too many variable from tire construction, vehicle weight, driving style...... The best way is to do the chalk test to find what gives you an even contact patch
Rampat
Boca Raton, FL
Explain this chalk test to me please.
TheLegend
