Looks great, what fog and headlights are these?Some minor tweaking. New steps and vinyl overlay for the RAM in the front.
View attachment 157103View attachment 157104View attachment 157105
Thanks you.Those tips look nice.
make your friend run while you ride the bike! simple lol
I did the same thing. I got a couple of wireless pads and a plug in for 115 volt. Then used two sided tape and put them on. They work really good and quick charging.
You are right. We had just put them up minutes before I took the picture. I am definitely going to tuck them up.That's the cleanest aftermarket install that I've seen yet. It would look even better if you tucked the wires into the channels on the left and right of your wireless pads.
That looks really good. I want to tint mine but thinking 20 or 30 front and something to bring the rear to as close to like 5%. Did you do a brow also? How does it look from inside?Got her tinted yesterday. 15% upfront with 50% over the factory on rears. View attachment 157126
I like the way the square pads look better than the round ones. I may replace it with a couple of square ones. We'll see.I did the same thing. I got a couple of wireless pads and a plug in for 115 volt. Then used two sided tape and put them on. They work really good and quick charging.
I like this!
I've been rocking my brain trying to come up with a neat way to install wireless charging in my truck. I have a jump seat in the front, which means no center console.
Can't identify a good spot to put and connect a charging pad. :-/
I'm an android user so I appreciate specifics shared.View attachment 157165
Checkout Course Motorsports mounts. This is their MagSafe mount, which works with iPhone 12 and later. A friend attached a ring to the back of his Android phone, and it works.
I hardwired a USB charger for mine, as the built in USB ports weren’t supplying enough power. But the same friend instead used his 115V outlet in his Big Horn. (Mine is a Longhorn, and unless I’m crazy, the only 115V outlet is in front of the back seats).
P.S. The upcoming Qi2 standard is based on Apple MagSafe, so before long, almost all phones will be MagSafe compatible.
Finished the install of my 32” Lasfit light bar.
• shift and grins brackets
• Lasfit 32” light bar
• 16ga wire
•Deutschmark connector (2 pin)
• Blazer remote
I didn’t do a write up but I would suggest watching waterfowler video or this oneNice! Write up?
How much of a pain is it to replace the solid bumper panel with the see-through one?I didn’t do a write up but I would suggest watching waterfowler video or this one
For the blazer controller it’s very straightforward and wiring is easy.
