Daverous
 - Sep 14, 2020
1) rear guidance lights are a BCM limitation. A 21+ bcm may fix this, however I haven't been able to get a dealer to commit to doing the programing. I'm not sure if a slave bcm with Jimmy's harness for the digital rear view mirror would help or not. Haven't tried that yet or asked?
2) try reading cvpm faults under diagnostics. Clear them if you have any, then try calibrating again. I ran into an issue recalibrating after a new lift and this solved it. Before the rear camera wouldn't take even after working previously.
