mhb1638
Damn that's pure sex right there.I took my truck to an easy trail today. Broke new snow tracks till we hit ice underneath at a hill and had to turn around. Definitely fun day.
But do they have 6-button covers? This one does not match our fobs.Thanks for posting. Yes this is it.
Lomax bed cover came in today. Took about 20 min to install. Also put on gator back mudflaps a few days ago. View attachment 11607View attachment 11608
Nice backdrop, how much was the Lomax cover?
Savannah Ga. Close to the ocean. Problem is not only what it did, but customer service answer to this. I don't like seeing hard water spots in my paint and on my windows that not even vinegar will kill (took a 2000 grit pad). Does it shine when clean, sure it does. This product might be great in california where it rarely rains....not here.
Is it just a simple swap? Interesting that Crutchfield says they don’t fit.Installed my new front speakers today one hr taking my time. Huge upgrade over stock highly recommended View attachment 11675View attachment 11676
What did you trim. Did you use Metra adapters? Part number? or did you cut and crimp?JonnyQuest the stock speakers do not have a real tweeter. I’m not going to get into specs but the JL,s are letting me hear things the stock speakers simply could not. It’s a big upgrade. I listen through the Tidal App which is high quality playback. As for install I would consider it straight swap as I worked in the car audio industry when I was young. Minor modifications to the speaker with at small side cutter was all.
What about wire adapters.Take the factory speaker and trim the aftermarket unit, just need to trim the very outside of the metal frame of the speaker so it sits flush.
What about them? Not sure what you are asking?What about wire adapters.
Did the factory wiring plug directly into the speakers or did you need to modify the wiring to plug into the new speakers.What about them? Not sure what you are asking?
