ferraiolo1
North Central PA
Had the truck for two years now. Never have been able to get an update OTA. Every few days I'd see a java popup message.
It’s done it to mine several times. Only time you notice it is when Bluetooth, and xm don’t work. If you just listen to the radio you would never know it’s happening.
AndBen
5thGenRams Supporter
Northern Virginia
yes they do
ive seen several people use the blazer wireless controller to enable u to use homelink buttons
when you get them up and working im curious to see the light output. waiting for good weather to get out and install my lower grille 30" bar and a pillar brackets. i havent decided on lasfit or aux beam for the ditch lights ( still debating what pattern to get also)
Son of a *****.
Weird. When you search by make/model/year on their site…that doesn’t pop up. Only shows 2010-2018.
6of36
Michigan
Permatex'd the **** out of everything. Flex seal tape inside and out. Silicone across the entire interior top edge of the window. Big rain storm coming this week so we shall see if it works
For info for anyone else that wants to seal their truck, Lexel caulk. Clear in the tube, dries crystal clear, can be applied wet, paintable. I use it for caulking everything.
TSL
Oregon
Of course.
But other than tower ping data, my phone isn't transmitting anything I haven't authorized.
And you can turn it completely off if you want to. Whereas in the video you posted ( which was fascinating by the way, although I don't think I quite dare disassemble my truck's head unit like that !) the guy points out that there is no option to turn off the transmission from the truck. I thought he made a good point : make it an option, sure there are some benefits to it, but some owners might not want them, or trust what might or might not be happening with data transmission.
HemiDude
Ohio
Well after 6 months of casual searching and 1 month of intense looking I finally found the truck I wanted. Almost custom ordered a 23 but I found this one about 500 miles away and bought it. It has more than I even knew it had. The Built to Serve package is awesome with the amazing looks inside and out, the chromeless body, the pano roof, digital mirror, LED lights, a bakflip tonneau cover, low miles (25k), ready to trailer, paint is pristine and the 12" screen is huge. Said goodbye to my 2014 Quad Cab after 8 years and 100k miles. This truck is just way bigger and tougher! And feels likes a Limited on the inside.
Congrats! Can't go wrong with a BTS
HemiDude
Ohio
Or you start your truck in the morning like I did yesterday and your main screen has been reset. Disclaimer: I didn't check to see if an update did occur, but I never had any issues with UC5 until the last verified update, so I'm just making a wild*** guess
Scap
Only listened to FM radio one time while stuck in traffic with my coworkers. FM today is like watching MTV. You remember how they used to play music last century.
I've never used XM.
Pandora streaming over BT is what I use exclusively unless I'm on the phone.
Rlaf75
Takes potshots
I've never used XM.
Exactly. Today's radio stations are all commercials. I use Spotify to listen to what I want when I want
ferraiolo1
North Central PA
1.25in should be perfect that’s what she said..
HemiDude
Ohio
1.25in spacers should put the edge of the tread just about flush with the oem flairs.
That's about where I'll be looking to be when I put my factory rims back on for warm weather. Haven't ordered the spacers yet, I was going to go a little thicker on the rears to even the wheels out. Did you get the same front/rear?
ferraiolo1
North Central PA
Yeah I did 1.25 all around. Trucks getting inspected tomorrow. So I can install them after that. Since they are illegal in my stupid state.
I’ll be using them with my vossens. But they are similar offset to the factory wheels
Rlaf75
Takes potshots
1.25 spacers will put the factory wheels right at the edge of the factory fender flares? If you can, please post up a few pictures if you got the 1.25 spacers.
