1BADRAMLIMITED
Chingon amigo next is a resenator delete? Or weld the “weep holes closed”?Installed mbrp 5143 direct high flow muffler.
Only took a small test drive around the neightborhood but couldn't be happier with the tone so far.
There is some air escaping at the joint thru the 3" clamp. Assuming its normal and its not gonna be completly seal with a clamp.
I might have welded it later on.
Sounds so much better in person than video
