You’re going to need to change the distribution box and add the wiring to work the extra door actuator. I’ve done it in a 4th Gen, I haven’t seen anyone attempt it in the 5th gens yet.Di anybody know how to connect hvac dual control thanks
If you are going from single zone manual climate control to a 12 in screen you need to make 1 bcm change with ALFAOBD to enable dual zone ATC then it will work.I have same problem the you guys find how to fix the problem thanks
you ever figures yours out? I have same issue.I have swapped my 8.4 no nav radio with a 12 inch screen and module and my hvac controls do not work i have a bighorn with manual temp controls what am I doing wrong
Can you please list everything needed? & how much did it cost you?I did mine and it works perfectly
Send me a dm and I'll send you a list. It depends on what you haveCan you please list everything needed? & how much did it cost you?
Message me please, trying to figure which module to get or modify. ThanksI can get everything you need. Message me. I also have a complete write up on installation
Hit me upI have same problem the you guys find how to fix the problem thanks
By any chance does anyone have the part number for the rubber piece on top of the radio bezel? The one the cover the screws at the top. When I went from the 5 inch to the 12 the insert is not to bog
Thanks6MB16TX7AA - MOPAR Mat. Storage bin. Trim: [*o0] color: [no | Factory Chrysler Parts, Bartow FL
Genuine MOPAR Part # 6MB16TX7AA - Mat. Storage bin. Trim: [*o0] color: [no description available]. Fits 1500, 2500, 3500. Ships from Factory Chrysler Parts, Bartow FLwww.factorychryslerparts.com
You won't need to change the module, just the screen.If I have an existing 8.4 screen with CarPlay and I want to upgrade to the 12 inch screen, can I buy just the screen and bezel or do I have to buy a new module as well. Sorry if this has been asked before. Also, is there a cheat sheet for doing this? Thanks in advance.
Where do you get the software? And has anybody figured out how to check the SW version on the 8.4” non-Nav?
UBC UBD UBE UBR UBU UBF UBG UBJ UBL UBN UBQ UBS | For the Uconnect 5 radios, there are 2 options:
4 | In the event the customer has a concern with their radio AFTER a radio replacement (i.e. the customer's connected services subscription has not transferred to the new radio), there may be additional radio part information needed. Again, a picture of the screen is most preferred.
Really? I was follow the upgrade in this forum for a long time and every time read that is neccesary replace the module the screen and the bizel, are you sure that the module that is in 8.4 fit with the new screen and the connectors match?, because i wish make this upgrade, the screen and the bizel are the cheaper part vs. moduleYou won't need to change the module, just the screen.
But you will need to change to settings in alphaobd to make it work.
Basically you have to let the truck know you have changed to digital controls.
Upgrading the screen will not give you any features you didn't already have. Such a factory nav or sat radio.
Can you explain exactly what you had to do to get it to work? You used your existing 8.4 radio module with the new 12 inch screen and it worked, correct?I did mine and it works perfectly
What radio did you start with? The 8.4 non nav? Or the 8.4 nav? What did you have to do/purchase to get it to “work perfectly”? You’re the only one in this entire thread that has made that statement!I did mine and it works perfectly
Can you send me a write up on how you swapped out your display to a 12”? I have a 2015 LamarieI did mine and it works perfectly
