Grill Ram emblem removal
Skinnycarr
Can someone tell me if it’s possible to get the “RAM” off of the grill without removing the entire grill? I can get to the clips on the back but not sure how they work?
DSOOBY
Dallas, TX
I used a box cutter to shimmy in behind the letter, then inserted a butter knife (or pry tool of your choice) and pried the letters off. they will break and pop off but your new ones will pop right in. You're going to have to be a little rough with it but it works, prying them off has been the common method here.
VaderRebel
Canada
I wonder if the 19's RAM grille letters are smaller than 4th Gen... because I hated them on my 16, but think they're fine on the 19.
Jsvt3
5thGenRams Supporter
Central Pa
Thanks for the info! I got them wedges up with an exacto knife and pried off from there. Took all of 5 minutes to pull and replace.
Jsvt3
Central Pa
Too dark for pics tonight. I did flat black RAM letters. I’ll snap a picture tomorrow morning.
Jsvt3
Central Pa
What did you replace them with? Pictures Please!
As promised. I also did hood emblems and all tailgate emblems in the same flat black. I forgot to order the doors so I’ll do them this weekend when they arrive.
Leduke1
How did you remove the tailgate emblem?
1200GS
Once you got the old one off, how do you install the new emblem?
Jsvt3
Central Pa
Like Al said, they have tabs that line the emblem up perfectly and my replacement came with adhesive in place as well.
nicks122293
Can Anyone help me out with where to buy the new RAM emblem for the front grill?
Al Czervik
Sag A*
Spokane, WA
Firej6460
How’d you get the hood emblems off?
Scott_65
SC
Just use a plastic pry tool on the corner and work your way around and it’ll pop right out. They’re the easiest ones to get off and l didn’t break any tabs.
MikeyLikey619
Man the A in RAM is giving me a hard time. The other two popped right off. Damnit!!
