Push to start oem wires or plugs ???? Need to locate
daviesnathan
Looking for someone who may have a lead on some dodge oem connectors ... might be a Longshot. But I recall someone on these forms
making other types of harnesses .. maybe someone can put me in touch with said person.
Basically looking for what ever plug ends come from factory that would plug into oem wiring and the back of the oem push to start plug (see attached photo) I was able find idata ch12 harness for the dodge ram had the plugs. But to Buy that harness for 80cad to Basically cut off the 2 plugs I needed seems like a waste..
Any help is appreciated
Eighty
Moderator / Dream Killer
Female connector: 776204-2 : Multilock Connector System Automotive Housings
Male connector: 345178-2 : AMP MULTILOCK, CONNECTOR HOUSING
And you’ll also need (4) of each of these (to pin the wires to the connectors):
Female connector terminals: 175180-2 : AMP MULTILOCK, RECEPTACLE AND TAB
Male connector terminals: 173682-1 : AMP MULTILOCK, RECEPTACLE AND TAB
lpartridge
Houston
This is the kit I bought just to get the push to start wiring harness. But the factory wire plugs into this, then that plugs into the push-to-start button. Then I pick the two wires that go to the red wire and install a tiny push button hidden switch in the side of the top tray. so I have to push this switch to be able to start my truck. for a kill switch
Fortin THAR-CHR7 T-Harness For Push-To-Start for Select 2011-2022 Ram, Dodge
