2020 Ram 1500 4x4 wont start, I need help!
jakeintexas
Hello friends,
I stepped outside today to leave and unlocked tried to remote start the vehicle. It didn't start but sounded like it was trying. I jumped in and pushed the start button. It starting making a popping sound through the speaker, would not start, and the gauges were going crazy. Then it start making a noise like it does when I remote start it and it wouldn't stop. I repeated the process and the same thing happened. I literally just hit 60k on it and just drove it last night with no issues. In the attached picture, I'm pointing to what I believe is the vacuum pump?) that was making a noise and wouldn't stop. It finally did after a few minutes and I'm assuming that is part of the start process. I came back an hour later and my truck is completely dead. The remote does nothing and pushing the button in does nothing, like the batter is completely drained now. It was perfectly fine before, so I don't know what changed overnight. Any suggestions?
When the batteries go bad on these Rams it’s often quick and painful. Sounds like the place to start
Since nobody else is answering....from their listing it looks like yes it will fit. Definitely buy a good battery. from just reading different posts here, our trucks are very picky with batteries. Many members have had weird little problem that turned out to be batteries. Some had their batteries tested, and passed, but a new battery fixed the issue.
Thanks! I’m going down to pick this up today. There was a similar one from the auto parts store but it was closer to 300
Thats a great battery but put an H8 in it instead, just remove the little spacer block in there, our battery tray is sized for an H8, no idea why they put an H7 plus spacer in there (cheaper probly).
Mine did the same thing a month ago and I did that battery in H8 size.
I had seen you post that, but couldn't remember who you were, or where you posted it, to tell him.
So the new battery worked, it fired right up. The only issue I have is the start/stop is disabled and I have a check engine light on now. I'm assuming it may have triggered with the power flickering when the battery went out. It also had the ECU alert but it went away along with the stability control disabled after I drove around the block. Any ideas on how to get my start/stop back on and how to clear the check engine light? From what I read, I need to disconnect the negative terminal on my new battery and wait 20 minutes and hook it back up.
Sorry to hear you are experiencing this, we certainly understand why this would be concerning. If you end up addressing this with your local dealer, please let us know via PM. We'd be more than happy to provide you with an additional layer of assistance for that process.
Callie
Ram Cares
Callie
Ram Cares
Thank you. The engine light went off but not I have no rear camera or passenger settings. I'm taking it for a drive later and will see if it will naturally reset.
It can sometimes take an entire day for all of your options to come back, and all of the lights to go out
Callie
Ram Cares
Thanks for the help, everything came back online and she is running great!
I received my truck and a week later left on a month long vacation. I had heard of sensitive battery issues and have read that if the truck is not started for 2 weeks or better you should charge battery before starting. I installed a battery tender on the truck. I'm hoping that will avoid issues. I'll be home next week to find out.
Thank you Ram Care! I sent you a direct message regarding an issue with my passenger side sun visor falling down again, obstructing my while driving. I'm hoping it is still covered but most importantly can be fixed so it doesn't drop down while driving.
Great to hear that it is fixed. It's crazy how sensitive all the electronics in these trucks are to the slightest voltage drop.
That's what I put in my 2016 Eco last month
Walmart, EverStart AGM, Group Size 49/H8, 850 CCA 170.00
When looking at this battery today, the H8 shows 900 CCA for $170 and the H7 is 850 CCA also for $170.
Did Walmart change the H8 model and give it 50 more CCA or do you actually have the H7??
Batteries certainly are much more expensive than they used to be, just like everything else. I had to replace in one of my Wranglers a couple of weeks ago, and I was a bit shocked.
Is your battery still holding up? I had a similar issue in December… replacedbattery with H7 AGM from Wal-Mart. Then end of January truck started dying again after sitting 30-36 hours. Dealer replaced BCM for $600 and drive me to Wal-Mart to get new battery under warranty. Mid-February battery was dying again if truck sat over 24 hours. Have found vacuum pump running as soon as I hook up jump box. Truck has been at dealer for 8 days this time and they cannot find source of battery drain. I’m sure my January battery will be shot from multiple deep discharges (<5v several times). Wal-Mart will probably give me trouble with 2 failures in just over a month. Anyone recommend getting it to another dealer? ( I have been using same dealer for 25 years on 20+ new cars/trucks) I think current dealer may be in over his head on a loaded Limited truck.
