34’s Tires on stock Rebel wheels?
kliffy77
Hi everyone, This is my first post here! I’m very excited I’ll be getting my 2019 Ram Rebel 4X4 with spring coils next Monday i love everything about the Rebel that said it would be really nice if i could fit a slightly bigger tires on stock wheels i was thinking 34’s as 35’s are to big for my taste is that possible? Thanks!
285/70-18 33.98"
295/70-18 34.29"
Thanks 19Jake any idia whats the stock Rebel tires size? Will the above fit without a lift kit? With no rubbing? Many thanks much appreciate your response.
I’m running Nitto Terra Grapplers in 295/70-18, basically a 34 x 11.5, on my stock coil sprung Rebel with no issues. Waiting for Bilstein to come out with their adjustable shocks to level the truck.
Thanks DIRTRIDER do you mind sharing a photo with us?
Guys please remember Rebel facotry wheels but bigger tires.
How’s the clearance? Do you think it could handle another 1/2 inch width?
Sorry Kliffy, have steel wheels and snows on right now, so no pic’s.450A0050-438E-4A65-AF20-E257C049A19B.jpegA9DE3004-5C25-4C24-A93B-3180171637CB.jpegA9DE3004-5C25-4C24-A93B-3180171637CB.jpeg
I seriously don’t know I haven’t even received my truck yet! But doing some early shopping to save time :)
I am considering 295/70/18 Cooper Discoverer AT3 XLT's on my stock Rebel. They are a 34.25" diameter with a 12" section width measured on 8.5" wheels. Any reason why these won't fit?
That comes out to 11.61” You’ll need a 305 to get the 12”
Thanks Smashy and are you saying that on an 8" wheel like my rebel, the 295/70/18 will measure 11.61" wide instead of 12" wide on a 8.5" wheel? If so, it sounds like the tire should work on my stock set up with no issues.
Yes. I have the stock rebel wheels too and was considering 305/65/18. Which will have a diameter of 33.6", a section width of 12.0", I have air suspension and I may have to put helper links to trick my suspension sensors.
I don't think you have anything to worry about regarding height with the 33.6", but are you more concerned with the width, hence tricking the suspension? I don't think either of us have anything to worry about with height, even me at 34.25". I was more concerned with the width and rubbing the UCA.
Yeah, the width has me somewhat worried. My 4th gen I ran 305/55/20 with no problems at all. I did install billstein 2” struts with it. I’d feel more comfortable if the rims were 9”, 8” is stretching it but I’ve read many threads in other forums where a lot of guys were running 12” wide tired on 8” with no issues.
