Sixxshooter
- May 4, 2020
Yeah I think your dealership scammed you.What if this little battery sensor keeps failing !
? I’m gonna call and find out . I’ll let you guys know what happened .
Could possibly just been other way around, and just a battery going bad needing replacing and a reset procedure like that turkeybird56 posted earlier if needed.I just filed a complaint with Ram . I spoke with them and explained to them my unfortunate situation . They said the battery sensor is not covered . They couldn’t do anything to help me . Now I’m wondering if there was anything even wrong with my Battery . They probably could have put the new sensor on and everything would have been fine . Cant trust any one !
No. The radio has memory. These aren't the radios from the 80s. It's running a version of Android.Thats a good point . I’m am curious about something though . After paying my bill and getting back in my Ram , driving home I noticed all my radio stations , FM & Satellite were all still the same . If they pulled out my old battery and added a new one , wouldn’t I have to reset all my stations again ? Did they just rip me
off ?
@turkeybird56 is this the bolt to take off and leave for 2 to 4 hours and then reattach?Are you saying to remove that 10mm nut that this charging clamp is presently on in the picture, and then remove the ground strap from top of the IBS ?? View attachment 151831
WOW - I bet my issues was not what the dealership said it was.Could possibly just been other way around, and just a battery going bad needing replacing and a reset procedure like that turkeybird56 posted earlier if needed.
It seems that these factory batteries are 3yr at best. A friend with a 2019 Ram 1500 had his battery fail almost 3 yrs to the date of purchase. It was probably installed in the truck at factory up to 2 months earlier.
Much good information in this thread and other battery threads that could help others.
My truck will be 2yrs old and around 30k miles this November and purchasing a new 7yr rated replacement battery. I’m using the larger H8 (49) battery and already purchased the larger Mopar (05033397AE) insulated cover. Cheap insurance imho.
