when would you like to add these sales codes?Anyone on these forums know how or is able to add sales code in vin?
When?? Whenever someone can. All work is done except the addition of the sales code I even changed the settings on the BCM using alfaobd. I just don’t want all that cleared in for some reason the dealership flashes my BCM.when would you like to add these sales codes?
Depends what sales codes you’re looking to have added. Not all sales codes are available to add to your VIN after the fact, basically only sales codes that mopar offers a kit for, such as factory remote start or power side steps. They can’t add sales codes to your VIN like passive entry, BSM, LED headlights or tail lights, etc.When?? Whenever someone can. All work is done except the addition of the sales code I even changed the settings on the BCM using alfaobd. I just don’t want all that cleared in for some reason the dealership flashes my BCM.
Code GXD. On this forum under adding the passive entry it say to have it added. I guess if one day the BCM gets flashed I can re instal using alfaobd.Depends what sales codes you’re looking to have added. Not all sales codes are available to add to your VIN after the fact, basically only sales codes that mopar offers a kit for, such as factory remote start or power side steps. They can’t add sales codes to your VIN like passive entry, BSM, LED headlights or tail lights, etc.
It’s very rare that they have recalls or TSBs that involve restoring the vehicle configuration, which will revert your AlfaOBD changes. But, if that were to happen, there’s a new procedure you can use with AlfaOBD so you don’t have to go back and manually change your settings again:Code GXD. On this forum under adding the passive entry it say to have it added. I guess if one day the BCM gets flashed I can re instal using alfaobd.
Thank You sir. I’ll check that out if I run into trouble can I reach out? Thanks again.It’s very rare that they have recalls or TSBs that involve restoring the vehicle configuration, which will revert your AlfaOBD changes. But, if that were to happen, there’s a new procedure you can use with AlfaOBD so you don’t have to go back and manually change your settings again:
In the active diagnostics list, just under car configuration change, make a backup file. This will be a quick restore point, so if anything the dealer does reverts your AlfaOBD changes, you can use the restore from backup file to get your settings back automatically.
Yup, no problemThank You sir. I’ll check that out if I run into trouble can I reach out? Thanks again.
Just recently been thinking about the same, because I had once stupid dealer reverted my AlfaOBD changes, without any reasons, since I had a lot of changes already, I start thinking about easy back up procedure and found this option in AlfaOBD. Was just afraid, that smth will not work and I would just loose all BCM settings. Is someone has done this procedure already, is it just uploading the same file, previously saved in Notepad format?It’s very rare that they have recalls or TSBs that involve restoring the vehicle configuration, which will revert your AlfaOBD changes. But, if that were to happen, there’s a new procedure you can use with AlfaOBD so you don’t have to go back and manually change your settings again:
Yes. I use AlfaOBD backup files all the time to restore a configuration to the BCM. That’s how I’m able to force some settings changes for new features that don’t exist in the AlfaOBD settings list, is by modifying values in the backup file.Just recently been thinking about the same, because I had once stupid dealer reverted my AlfaOBD changes, without any reasons, since I had a lot of changes already, I start thinking about easy back up procedure and found this option in AlfaOBD. Was just afraid, that smth will not work and I would just loose all BCM settings. Is someone has done this procedure already, is it just uploading the same file, previously saved in Notepad format?
Thank you for the information.For iOS folks using OBD JScan, it also has a backup/restore function. Creating a backup isn't particularly intuitive:
- Tap the gear icon in the upper right
 - Select Trace & Restore Adaptations.
 - Tap Restore tab at the top
 - In the lower left, tap the yellow '...' button.
 - Tap green "Start backup" button and confirm.
