Jack Points When Using Jack Stand - Pics Inside (Tire Rotation)
umang2004
For tire rotation the back is lifted from the pumpkin and fronts individually.
For oil change, I raise it to off-road and place jacks under the frame rails.
Hey thank you so much! DO you think you could try to get a better picture for the front jacking point location? im wanting to do my oil change soon. if not its okay thank u so much
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Just under the A-arm.
What you need is a 3.5 ton floor jack with 6 ton jack-stands to keep you safe.
Not kidding...
umang2004
okay thanks,sorry im a visual kind of learner but ill see! i also have 3 ton stands and a 3 ton jack. you dont think its enough?
KCURTMAR91
plenty as technically most of the 1500 are less than 6,000 lbs (3 Tons) so a single jack stand could support the entire truck as could the jack (I think some fully loaded 6'4" 4x4 etc trucks are just over 6K, but not sure, plus there is no way to jack up the entire truck using a floor jackstand). So one jack stand supporting one 'wheel' is probably carrying less than 1/4th (1,500 lbs) of your 3 tons, you have plenty to spare.
mikeru82
The Palouse
I just use cardboard. I save cardboard sections for working under trucks, painting, etc.
Been there, done that. It's better than laying on cold concrete (or worse). But I'd rather just raise the suspension and continue to roll with my creeper. It's easier on the knees. Also, that way I'm not storing a bunch of otherwise useless cardboard in my garage. I'd rather use that space for other things.
HEMIJAKE
Potter County, Pa
After a 2.5 level and 35's, I just use a creeper too. Much easier. Obviously stands and jacks are still needed for rotations.
The 6-ton jacks are nice because they are taller. My truck with the front level, 1" rear spacers and taller tires, my 3-ton jacks are just about useless if trying to use them on frame.
Ramroo
Good plan. Mostly I use the cardboard to catch the oil I always spill, especially transferring the oil to the containers to take to recycle. Wipe the oil off the cardboard instead the garage floor.
mikeru82
The Palouse
Whatever works best for you. (y) What do you then do with the contaminated cardboard when you eventually replace it?
kapinallinen2
Southern Maryland.
3 ton will hold the weight just fine. 6 ton jack-stands with larger foot print will hold it even better, major difference in stability. 3 ton jack-stands are pretty useless for full size truck application IMO.
mikeru82
The Palouse
3 ton will hold the weight just fine. 6 ton jacks with larger foot print will hold it even better, major difference in stability. 3 ton jack-stands are pretty useless for full size truck application IMO.
I agree with your recommendation if someone is shopping for jack stands. But @umang2004 was asking if the 3 ton stands he already has will be sufficient. The answer to that is yes, they will work just fine. I've even used 2 ton stands under the rear axle and 3 ton under the front end when I was in a pinch. But I prefer to use my 6 ton stands when I'm working at home in my own garage.
kapinallinen2
Southern Maryland.
I`w owned the orange 3 ton stands for 3 decades, they are fine, much prefer the 6 ton.
djevox
VP of Creative Thinking
MD
any pics of the lift points for a two post lift?
Pull it in until the door handle is inside the posts and it’s a pita and you’re cursing while getting out. Push front arms to forward most flat spot on the frame. Push rear arms to the rear most flat spot on the frame. Lift vehicle up until all wheels are off the floor. Push up and down on the rear bumper a couple times like you’re trying to jounce the suspension. If you hear banging from the frame jumping up and down on the pads, then you need to readjust because you might drop a truck on your head. Done.
