First visit to the CAT scales
tjbarney
We are fully loaded with the travel trailer and we’re able to make it to a cat scale today. Only did one weight though with WDH engaged. With these numbers, it appears we are over our GVWR by 160lbs 😞.
Steer Axle: 3440
Drive Axle: 3820
Trailer Axle: 5820
Gross Weight: 13080
Truck door weights say:
GVWR: 7100
GAWR Front: 3900
GAWR Rear: 4100
devildodge
Moderator
Central Pennsylvania
Steer Axle: 3440
Drive Axle: 3820
Trailer Axle: 5820
Gross Weight: 13080
GVWR: 7100
GAWR Front: 3900
GAWR Rear: 4100
Looks perfect. Maybe with a trip and doing the 3 weighs you can tweak the WDH and fix you 160lb problem.
I would not be afraid to travel like that...as you use fuel it will make the 160lbs less as well, assuming you did the weigh with a full tank of gas.
Brutal_HO
The Mad Irishman
Douglas County, CO
One thing I almost always see overlooked by both those new to trailering and those giving advice.
The use of a WDH not only transfers weight to the front (steer) axle of your truck, it also puts weight back onto the trailer axles.
This needs to be understood when you're setting up and doing scales so you know why/where those numbers are affected.
You're inserting a big lever at the ball that pushes down on both ends (truck front/trailer axle).
Best video you can watch to understand what's going on is right here:
I normally post this up when there's a debate air bags vs WDH, but the info is appropriate for this thread.
SnowBlaZR2
Fuel Economy Champion
FL
Steer Axle: 3440
Drive Axle: 3820
Trailer Axle: 5820
Gross Weight: 13080
GVWR: 7100
GAWR Front: 3900
GAWR Rear: 4100
These are the latest numbers with our WDH. Literally the heaviest it will be.
Steer Axle: 3520
Drive Axle: 3860
Trailer Axle: 6720
We're 280 lbs over, but I'm not worried about it as we're generally traveling much lighter and I still have some work to do balancing everything after stopping by our storage unit. We're also full timers, so the truck sees a lot of miles with the camper behind it.
I'd bet you can get some cargo moved around and your hitch adjusted to get all or most of that weight back.
tjbarney
Thank you. It is towing very well and the measurements of the wheel wells and trailer level are good when we adjusted the WDH.
I’ll have to figure out how to do some adjustments to it to make it more even. It has 5 washers in the Fastaway E2 hitch. Dealership didn’t give me any extra washers either.
Oh, tank was full as well. We upgraded to the 33 gal from the 26 gal. Between that and the 100lb Generator in the back that would be my weight overage. In the bed I have one 40lb folding ebike, 19lb folding kayak, and two sets of golf clubs. In the back seat floor board the other bike and kayak. This is as full as we will ever be as we are full timing it for 3 months.
I had roughly 100 ish pounds of fresh water in the tank on the tt as well. Normally wouldn’t, but wanted some to test the weight.
SnowBlaZR2
FL
What were your measurements?
This is my last measurement I took when I was also able to weigh it. Weight restored was calculated at 64.71%, so pretty close. If you're getting your front measurements with the WDH close to what they are unloaded and it's towing well, I'd be happy with that.
tjbarney
Front height of wheel well with the WDH is right at what it is unloaded, or extremely close to it, like within a 1/16 or 1/8”.
