Added oem power running boards. Uconnect app not installed?
Zrxpilot
Just had oem power running boards installed at the dealer. They work fine ( extend when opening the door and retract when closing the door), however the app to keep them extended/disable is non existent. Called the dealer and the service mgr just said to bring it back. Looking to avoid this headache if possible as its another day off from work.
I read somewhere that some had a to wait a couple days and it magically just showed up. Or maybe just use alpha obd to enable them?
moparleo51
had mine installed at the dealer , and i believe it took a day for it to show up in the uconnect.
Darksteel165
Massachusetts
Can enable them via Alfaobd.
And yes it can take up to 24 hours for things to show up.
It is the stealerships job is to enable them if you had them installed at the dealer.
Zrxpilot
Thank you. Attempted to use my alpha obd to activate and even that gave a message it would take 24 hrs to activate. Well see.
Jimmy07
Honorary Site Supporter
Reboot the radio two times in a row by pressing and holding the power button until the radio shuts down.
Zrxpilot
Issue believed concluded with a trip back to the dealer for what I presume was a flash. I now have the fully functioning app controlling manual deployment/retract/ auto/storage modes. App was installed and functioning by the time I left the dealer parking lot.
Had what I thought was a bug. After activating the manual deployment/retract functions in the controls tab, the normal auto function quit working. Ie, I could get them to go in and out pushing a button but the auto mode didnt work after playing with it.
Took it back and spoke with the tech for awhile. Got it to work triggering the following conclusion: After activating the deploy/retract functions, it stays in manual mode allowing only deploy/retract until the truck is shut off and the keys for the vehicle are removed allowing the uconnect to sleep. (his words, not mine). When the uconnect awakens again on a normal start it reverts back to the default state allowing auto/stow mode.
Tried the exercise a couple times with success.
Darksteel165
Massachusetts
Hitting the manual deploy\retract has nothing to do with the other setting.
There is a uConnection setting for "auto" or "store" when it's set to auto it opens and closes with doors. When set to store it stays closed.
I can deploy and retract my steps with the button and it stays in auto.
When you set it to store. The steps stay in until you change it back to auto. That would just be stupid if it changed back. You are suppose to put it in store when it's snowing and icing up where you think it might be damaged if it deployed, it would make no sense if it resets after you turn off your truck.
But either way glad it's fixed for you.
Idahoktm
North Idaho
I think he's talking about the "retract step/deploy step" button on the "controls" page at 1:26 on this video. I use that button when I wash my running boards and if I remember correctly, they function as he described.
Darksteel165
Massachusetts
He has a 2022 which is uConnect 5 not 4.
There is a button on the vehicle page that says deploy step. When you deploy them the button goes grey and they stay out. When you hit it again they go in.
Auto-Store is a different menu which does NOT reset by itself.
Idahoktm
North Idaho
Yep, you just confirmed what I said and it sounds like both versions of UConnect are very similar for the power steps.
Idahoktm
North Idaho
I noticed something about the Ram power running boards that I hadn't seen before.
