- May 28, 2022
So in the other thread it said something about if you have neither the fcw or acc, you should select the mirror with fcw? Also will I need a new shroud cover for this?
Everything is in the first post on this thread. You don't need a new cover.So in the other thread it said something about if you have neither the fcw or acc, you should select the mirror with fcw? Also will I need a new shroud cover for this?
Don't buy the entire CHMSL and just buy a replacement camera, then mount it somewhere suitable and run a cable.I need to do this to my truck, but the third brake light will be blocked by a track and tent. What can I do for an alternate camera?
Any chance you know the part number to just the replacement camera?Don't buy the entire CHMSL and just buy a replacement camera, then mount it somewhere suitable and run a cable.
You can't use any camera with the digital rear-view mirror.
Try here.Any chance you know the part number to just the replacement camera?
Did you mean CAN or CAN'T?Don't buy the entire CHMSL and just buy a replacement camera, then mount it somewhere suitable and run a cable.
Ok thanks. Just wanted to double check.Can't, can not.
Jimmy07 makes the harness. It has all the connectors and is plug and play.Does anyone have a write up for the Wiring harness? Finally got everything together and I’m not sure where to connect the new bcm to
Yes, it's in the first post at the bottom.I guess I should have been more clear - I have the harness, I was asking for an install guide. I haven’t taken off my old rear view mirror yet but there were a couple stray wires in the new wiring harness that look like they need to be added into an existing connector. I wanted to see if there was a write up for the 2020 with the additional BCM before I started poking around myself.
You don't. At least, no way we know of.I have a 2021 and added this mirror a while ago, I’ve had no problems except my mirror dimmer doesn’t work anymore. It was plug and play for me so I made no BCM changes, any ideas to get it back?
There are two different part numbers for the digital rear view mirror one is just the digital part the other comes with the auto dim and full speed warning collision. The one with auto dim is 68448641AB (Digital Rear View Mirror w/AutoDim and Full Speed Warning Collision). Don’t know if that is your problem or you have some JScan issues if you already had auto-dim.I have a 2021 and added this mirror a while ago, I’ve had no problems except my mirror dimmer doesn’t work anymore. It was plug and play for me so I made no BCM changes, any ideas to get it back?
