Falken Wildpeak 35/12.5R20
TN47361
:( after research I decided to order the Falken Wildpeak AT3W in a 35/12.5R20 for the new truck using the factory wheels. Test fit the front and everything went good with no rubbing on fenders BUT....you could barely fit a piece of paper between the upper control arm and the sidewall of the tire. :mad: Looks like I have to order 285/65R20 which are of course on backorder.
I had the same wildpeaks delivered on Monday, ordered 295-60-20 wildpeaks on Tuesday and sent the 35's back. My new wheels are -20 offset, didnt want to take a chance on any scrubbing
Are you on a leveling kit? That only had that much room behind tire to control arm?
On -20 offset you will not have rubbing to the inside of wheel well components. Just More on the turning..
Ended up with the 285/65R20 and love the look. I do get some rubbing on full turn but that is without a leveling kit or lift. I wanted to do the 3.5 lift but was told between that and the tire size it wouldn't fit in a standard 7' garage door. :-( may be stuck just with a leveling kit.
Measure and see. A few people said it still got on their 7' garage with 3.5" and 35s.
Any pics guys? I just ordered the Readylift 2" with upper arms for my ORP BigHorn, and I'm seriously thinking about the 295/60-20 Falken Wildpeak tires to put on the polished Laramie wheels I picked up. I like the Falken tires, as that's what comes on the ORP trucks. They are nice and quiet, and seem to be very good snow and general use tires.
285/65r20 no level or lift yet
This was a problem on the 4th gens too when trying to put a 12.5 tire on stock wheels. A lot of people (including myself) used 1/4" spacers to move the wheel out a tad.
Something like this: https://www.amazon.com/6x139-7-Whee....7+.25+spacer&qid=1570122437&s=gateway&sr=8-3
Did you get away with using stock studs with the 1/4" spacer? I'm wondering about that but really want to go with a 1/2" spacer and was wondering if you can use stock spacers with that much.
Yep, stock wheels, lugs worked fine with that small of a spacer. Again, this was a 4th gen. This new truck may be different.
Sent from my SM-G960U1 using Tapatalk
I know this is an old thread, but im in the same boat rn... I purchased the motofab 2.5" level still dont have it installed yet. but looking to get 35/12.50/r20 wildpeaks or going with 295/65/r20 KO2s.. did you have any difference or any thoughts after you did your level? thanks, love the stance and look of your truck !
