Ram-a-Kin
- Jan 27, 2022
How hard is it to pull the glass mirror off?Sequential LED Side Mirror Marker... https://www.amazon.com/dp/B0B3N47QVW?ref=ppx_pop_mob_ap_share
I found it easy using a screwdriver. Others use suction cups.How hard is it to pull the glass mirror off?
Judging the light pattern shown in the video, it doesn't look like they will blind oncoming drivers. The main beam is still focused low. What little scatter there is above the main beam won't be enough to annoy drivers. Especially if using amber lens. And if these are designed to go in place of the factory fog lights I would hope there would be some sort of adjustment that can be made for aiming them
Got my rear tow hook situation figured out, a little drilling and they went on.
Then was rearranging stuff in the bed and back seat and discovered this lever, anyone know what it does? And turns out one of my seat belt bolts was very loose... come on Ram...
Are those hooks gold? They look great with your truck. Nice break from always seeing red ones…
I’m looking forward to both pics of what the lens looks like in the day with the lights off & those night shots. Right now I just have Amber/orange Lamin-x film over the stock lens.
My original plan was to match the 3 bottom lights by getting the Shifts & Grins brackets & Diode Dynamics center LED light bar in amber because my plan is to battle the fog and living in a rural area also, but these fog lights are about the same price and looks like they might be less work. What do you think? I’m also thinking it’d be a little pricey & overkill to have DD fog lights AND DD center light bar. I haven’t priced the fog bezels vs the open center grill yet either.
I was originally looking at the Baja Designs the other day & I do like that they’re a little less money & come with the bezels but obviously there’s a little bit of a power difference. I wish there was a way to see the differences better.
Yep, I still owe photos. Unfortunately, my truck is back at the dealer for a problem with the adaptive cruise control, forward collision warning that they still have been able to fix. I’ll have to post about that soon, as I hope somebody will have ideas because the dealer so far hasn’t been able to figure it out.
Anyway, when I get the truck back, I’ll take some additional photos and post them.
What was the price for the Baja kit? I thought Diode Dynamics was less expensive. I paid $380 for everything (including the replacement OEM trim pieces) from RetroShop, but it looks like now the price has gone up to $440. That’s for the Pro level; Sport is $120 less and max is $200 more.
I can send a pic of the buttons, they are really nice IMO and the key is held in place by a raised plastic outline of the key shape. No noise at all or Id throw it away.
Sent from my SM-G781U1 using Tapatalk
The buttons are injection molded
There's a guy local to me that does car detailing, paint corrections and ceramic coating. His actual namez given to him at birth, is Shyne HarderWellp I’m back on the AJT bandwagon. Just orderered.
It’s interesting, I remember back when i ordered the one for my tundra he had like 3 fobs available. Now he has like 21 with all the button combos. So it’s the majority of his stuff. And I find it cosmically funny that his last name is “Truckey” and he makes a ton of “truck keys.” it’s great when you can tell someone was meant for the stuff they do. Sort of like the days when people named Smith made swords and armor for a living.
Which rear bumper step?Gave it a bath and installed rear bumper step finally.
Probably turned key in before you reconnected the IAT sensor in the tubeInstalled a S&B CAI, did't follow the instructions and had a check engine light. After unhooking the battery its gone.
I use a clay bar and it works great for water spots on glass.Scrubbed hard water marks from the side windows and pano moonroof with 0000 steel wool and Barkeepers Friend. It pretty much sucked and I still have the front and rear window to do.
I believe I did.Probably turned key in before you reconnected the IAT sensor in the tube
